Just ask any electronic storeHI, where did you buy at 760
Thanks
Eeeh ur 760 got include delivery... ..
harV 811leh But got deliver
Included delivery..., if Harvey, best and court can sell at $811 those electronic shop sure can sell cheaper...
Hi I am looking for a basic fhd led no-frills TV. My viewing distance is about 3 meters therefore I think 40 inch will
Be ok ...(will 48 inch make the hd starhub cable video very pixelated?)
I don't want edge lit. I want the LED where individual LEDs can switch off to
Acheive deeper black(what is the term ah?)
Since there are
So
Many options and brands
And hd(1920 by 1280) is basically available on every offer....I want to
look for the TV that has the best sound output...
Any particular brand suggestion.
I don't care about warranty since I will
Just throw away and get another one. But I die die don't want display set(maybe will
Avoid courts,gain city and audio house)
It seems you want the impossible by requiring the TV to be "no frills"and yet want best sound output and want deeper blacks. If you want deeper black, its either OLED or full array LED which unfortunately is much more expensive.
Hi, can I have some guidance for a at least 42inch TV? I have a budget of $600.
Hi guys, been a while since I shopped for a TV.. no choice, LG TV just died and looking for a replacement.
Looking for the best picture quality and maybe good warranty.
Have narrowed down to the following but difficult to get a side by side comparison and they always show different stuff from different sources at the stores.
Toshiba 40" L5450
Toshiba REGZA
Samsung 40" UA40H5100AK
UA40H5100AK 40 Series 5 Full HD LED TV | SAMSUNG Singapore
Samsung 40" UA40H5303AK (this has ports facing the rear and not the side, may not be suitable for wall mount)
UA40H5303AK 40 Series 5 Full HD LED TV | SAMSUNG Singapore
Panasonic 42" TH-42A410S
TH-42A410S LED TV - Panasonic Singapore
Come to picture quality, I do think Sony has an edge.
Some suggestion as below:
Sony 40" LED HDTV KDL40W600B - Lion City Company Online Store
Sony Bravia 40
I always have good impression of Panasonic products as they are quite durable though I do not know if the same applies to their LED TVs.
Toshiba 40" L5450
Toshiba REGZA
You missed the Toshiba 40" L5450 timesale on Qoo10 2 days ago. It was going for $399 but limited to 30 sets.
Not sure about the other 3 but this Toshiba model uses backlit LEDs. Most budget TVs use edgelit technology.
where did u see that Toshiba L5450 uses backlit leds? I can't seem to find these type of technical info..
I think L5450 is edgelit leh..
