Air conditioning - Any recommendations please??
AciDJC
You are right. 3MKS71 much better than MHI.
Unless you go with Mitsubishi Electric : ME.
In term of cooling & quiet from ME do much better than all.
But no point, I guess ME much expansive a bit.
Panasonic, hitachi, Sharp, MHI all lower budget a bit.
Due to MHI FCU more difficult to maintenace, unlike ME have a easy clean access into blower.
ok well noted,
so in terms of better is ME (best) -> Daikin -> MHI??
I will drop by later to look at their ME 3A28VA see how much it cost.. if price not much diff, might as well change to 3A28VA
kimsim
Suspended
ok well noted,
Just read below recent member Jeremy1 replied from thier system 2, got power on, but can't feel that Aircon like working and he just set to 25c with fan bar 2, cold like winter.
NOISSUES
25 deg C should not cold like WINTER. If it is the case, sensors must be haywire and need to be replaced. Otherwise, you have to monitor your electricity bill.
zeppelin
Bro, the forum is a casual talk, he's using a metaphor to describe the room is already cold with just 25deg setting. And I believe everyone here can understand it.
kimsim
Suspended
Honestly my house also used ME, for our room and living room almost set with 25C for sometime just play with fan speed only.
Cause if less than 24C cold until foot, can't even sleep as well.
Jeremy1
Sorry, if my statement a bit confuse.
Initially, I set at 16 degree full fan blow and it's really feel like winter and the fan was so powerful and noisy ( then i was wondering why Mit claimed it's the most quietest :s11: )
So I then tune down to 25 degree with fan blow setting at 2 bars and it's cool enough already, help to save electricity and also with this fan setting, it's really very quiet but of course it's take longer time to cool down the room.
I think maybe other brands should also be quiet with my current setting.
kimsim
Suspended
ME claims his quietest on 19dB, so far like MHI, Pana, Daikin for quiet mode at 22dB only.
You can try with 24C these is more faster cool down the room temperature.
Netiya1987
Just install my Mit Sys 2 inverter and so far it's good.
I just set to 25 degree, it's so cold already and blower fan set at just 2 bars enough to cool the room within 45 mins.
The blower fan set at 2 bars is so quiet that it's feel the aircon was not on at all.
That why i told you before. My friend have such problem. It will be worst after 2years. Ask GC help you on it as you purchase from them.. And we can see how is the after sales service.
Netiya1987
Where do you guys usually go and buy? Gain city?
Most of my friends and family used to buy from GC. But their after sales service warranty have term and conditions or your warranty will be void.(eg: 1year at least 4times servicing and have to be BCA approved with receipt as prove.) basically is taiji after sales service..
Netiya1987
Yes aircon cannot be cold like winter. If like this then confirmed up lorry already..just brought only so fast up lorry.. Mitsubishi Starmax should cover all this. Ensure that you approach the seller.
Netiya1987
At my block, Mitsubishi was the most common, followed by Panasonic and LG. But truth be told, every experience with any brand is kinda heng suay.
Nice said.. All aircon is the same.. Just the warranty part make the difference.. And make sure u personally go down to the shop to take them out before buying. Trust your own judgement.
Jeremy1
Like this is good....................:s12:
My friend LG after 5 years a lot of issue.
Jeremy1
But the SA told me different thing. If you looked at the GC Aircon cleaning, they also not every year 4 times.
My colleague had their service and the first year is 1 time and subsequently 2 tines then 4 times.
kimsim
Suspended
Seriesly just talk talk only... Who wanted for winter feel, these is over cold... Uncomfortable at all.
The most comfort would be set at 25C with low fan speed.
I wanna realise LG Artcool mirror 1st still working now?
From the flat & slim version, not the latest black mirror.
LoxXxA
I just got a quote for the following system 4 Daikin inverter.
03x FTKS25 (9,000 btu)
01x FTKS60 (21,600 btu)
01x outdoor unit 4MKS60ESG
-Upgraded to Copper Tubing Gauge 22
-Upgraded to Keystone Electrical Cable
-Armaflex Class1
-PVC Drain Pipe
-Nylex PVC Trunking
All of these for $3970. Is the pricing reasonable?
kimsim
Suspended
-Armaflex Class1
-PVC Drain Pipe
-Nylex PVC Trunking
G22 copper topping how much?
If you not consealed piping, but upgrade to G22 very useless..
The pipe just expose at outside less than 20cm for connected to compressor only.
Look like 4MK60ESG really lower capacity than 3MK71 compressor
I though Daikin will package with 4MK80ESG for more power.
60 = 20k btu only
71 = 24k btu
80 = 27k btu
kimsim
Suspended
I knew why your question for our Aircon take sometime for cold down room.
Actually I'm find out also, cause my JB home all Aircon was installed single split very fast less than 15mins can be feel that cold enough, after move to Sg here and use the multi system and why so slow..
The answer was by HDB flat lock on current limit at 8.5A = 1920w, if don't have it current limit, I think would be same like single split faster cold down that room.
Lock meant don't have optimum power maximum draw from compressor when starter kick in.
LoxXxA
He never mentioned top up price. He just email me say that all these are for $3970. Dunno if its typo error regarding 4MK60ESG or 4MK80ESG. This i need to confirmed with him again. But pricing wise is it reasonable?
60 = 20k btu only
71 = 24k btu
80 = 27k btu
kimsim
Suspended
Pricing is ok.
Just have to double confirm that outdoor unit.
