Ask a Bicycle Question - Part 5
wulu1_69
This person is cycling on a Tern Verge X10 with 451 wheels. His configuration is 56T front with smallest rear cog. So his biggest gear ratio is 56/11 = 5.1.
This is his video cycling with roadies. You can check it out his other videos..
Can imagine how fast he will be if he is using a high end carbon road bike. But then he needs a foldable road bike due to space constraint.
Did he upgrade the bike components?
wulu1_69
Did he upgrade Any components?
BradenHeat
wow.....judging from those videos, makes me really wana loan that type of road bike and try the top speed.......:s22::o=:p
BradenHeat
You sound like you have been poisoned!:s13::s13:
plus topgear s22 ep01, rofl...that bike.....DAT BIKE MyWay — CICLI PINARELLO S.p.A.
haha.. im currently just curious.... someone lend me theirs for just 1hr.... wana hit top and see and judge just how much a diff is, i do know MTB is slow....but the hybrid vs mid-tier road bike unbelievably big :s22:
Though the pick up for hybrid still hands down... other than that....the 9th gear/last, makes peddling very tough and gruesome:o
okay side question : when i hit top gear on 9th....theres......ticking/ tapping sound but if i downshift to 7th it seems fine..
should i bring it over for your mech to take a look ?>
SmilingDevil
Just tuning, bring it down anytime. wont take too long.
Jay Bee
SD will you be at shop tmr? can i borrow your chain ruler to measure, if too long then time to change, cant tune my shifting properly :s22:
Jay Bee
108rpm...... thats is super quick..... actually the guy infront also has high cadence, makes the whole video looks like fast forward :s13:
erwinrommel
He changed the stock wheels from 406 to 451.
Change to oval chain ring 56T.
Changed from flat bar to dropbar.
But that's him. Almost none of us can reach that sort of cadence at such a high gear. Its his fitness, not the bike.
jes205
I don't doubt his fitness for one minute but from the shadow in these videos, he's riding road bike lah.
Sadisticnoob
no la is folding bike. you see end of the video, near saf ferry terminal can see ths shadow
the guy in the 2nd video damn strong siol,, he pulled damn long, like almost the whole stretch of coastal. this guy pullled like 2 lamp post then swap liao
and in 2nd video, the video is ff at 1.2-1.5x
Sadisticnoob
you wanna try just pm me, i can let you try, theres a loop around my hse. just need you to bring your pedals
i can mount gps data to both bike, so you can try 1 hour each.
erwinrommel
I assure you its a Tern Verge X10. Modified of course. :s13:
I think they were practising some rotational drafting.
Anyway, PGSK riders are known to be pretty fast road bikers.
