LesterQ
- Jun 12, 2010
It's a known issue with it. However, I cannot hear it unless I press my ear against the tweeter. For your case could be power/ source not clean
which dac are u using? or onboard sound? if u are using onboard sound i will strongly recommend u to get a dac. IFi IDAC is a good budget dac which i will recommend
you can try to disconnect the speaker input totally. and see if there is still issue with the noise. if yes, might be due to dirty power input like wad iceapt says.
if no, might be due to dirty input signal which causes this.
Okay. I think I have both..
Firstly, yes I'm using oboard. I bought this speakers knowing I will eventually have to get a dac due to the digital noise from my PC. Comments about Schiit Modi?
Disconnecting speaker input from PC. There is the ultra low white noise that icecapt says is a well known issue. Hissing noise. With the input connected, it becomes an intermittent tik tik tik noise on top of the white noise that is heard without input connected.
