Ask a Bicycle Question - Part 5
Sadisticnoob
Very newbie to bicycles, just wanna ask a few questions:
Question 1:
When bicycle is at a complete stop, i would normally grip my left brake to avoid it from rolling around (especially at a traffic junction).
Is there anything sold on the market, that has a simple lock so that once i press it, the brakes will auto lockup and i don't need to keep gripping my brake?
Question 2:
Is it normal for disc brake to give abit of "screech" sound when braking? I never hear such "screech" when i was using my supermarket bicycle with those rubber clamp brake.
Question 3:
Bicycle accessories shop seems to be very scarce in SG. Other then going online to buy, are there any good and affordable shops that specialize in bicycle accessories?
Thanks in advance.
1. no idea why would you want that since locking up the brakes will cause you to fall off the bike if you forget unlock it.
2. your pads could be contaminated by oil or water, might need to clean.
3. The best stocked in Singapore IMHO are rodalink tradehub, tay cycle and KHcycle. the rest are too small
Phyber
Then must remember to unlock lor.
Anyway thanks for your advice. :)
Zephryro
Any cheap bicycles to recommend for trail riding? Dont want too expensive as my area has lots of bike thieves. Cant park indoors as well. Rode a polygon quattro before and seems to handle to trails quite well. Any recommendations near that range?
Not a too hardcore rider. Will usually dismount if the trails seem to challenging.
Sadisticnoob
But would it aid in speed(?) Just wondering.....and would it able to absorb small rocks (?)
Sent from Sony D6603 using GAGT
As for speed, using a mtb with unlocked suspension and slick (botak) , can follow road bike no problem, but then my gearing would be maxed out.
it will not asborb small rocks, typically this kind of tires the pressures are relatively higher(around 60 psi) than hairy tires it will just deflect the rocks
BradenHeat
Ah... Noted...shall ask smile later haha thanks !
Jack_Chen
I have no idea what BB. The parts that came with the bike should be same as listed on the website.
So can I just find a 48T triple crank and a new chain? Will any Shimano or SR Suntour fit?
Crankset
SR Suntour NEX, 24/34/42
Bottom Bracket
SR Suntour Cartridge BB
Shimano Altus FC-M191 triple crank 48/38/28T, Square taper
Requires 120~122.5mm BB length
80 RMB including Shipping to Shenzhen.
Jack_Chen
where can i buy bicycle like this? budget < $1k.
http://hellobicycle.com.sg/products/creme-ristretto-doppio-dynamo-black-8-speed-1
hellobicycle too expensive liao but i love the sleek outlook of this bike
Hmm, Cheap John's/Sembawang - Gios Spazio touring bike. Has both flat bar and drop bar options.
Ask first, likely to have good price below $1k. Comes with Campagnolo groupset
patcheon
https://www.facebook.com/video.php?v=794693693940078&set=vb.391367257606059&type=2&theater&notif_t=like
Here is a video link that I have done up for those heading from ECP to Marina Barrage.
So this path ends up at the Gardens By The Bay East entrance. Think couple of weeks back, saw a clip where they use a path where they have to cross some unpaved portion then end up at the Barrage itself. Dunno will there be another path over there eventually. But nevertheless, this is great as no longer have to go thru the mess around Fort Road to head towards the Gardens By the Bay and Barrage from ECP. :)
