What The Flex can the LG G Flex2 do?
xtramadness
The LG Flex 2 gives and provides an ergonomic hold on the phone which should sit pretty comfortably on your palm. Together with its large crisp 5.5" screen that sports a 1080p resolution and coupled with 2GB or 3GB ram, 16gb or 32GB of internal memory respectively, it has pretty much everything that an average user needs to run his stuff daily on a phone.
Including the of up to 128gb microsd for expandable memory (well, funny because 200gb is now out), you can carry all your memories together
Why the twin model with 3GB ram and 32gb internal memory or 2GB ram and 16GB internal memory might be puzzling but probably costs?
It will be running on the latest Android OS - Lollipop
POLED in Full HD 1080p screen, resulting in a resolution of 403ppi.
The screen is protected by Dura-Guard Gorilla Glass 3
With the heart powered by the latest Qualcomm Snapdragon 810 quad-core processor running 2Ghz, it also supports native 64bit processing
OIS+ on the 13 MP (megapixel) camera for the back (rear) with 4K high-resolution video recording and 2.1 megapixel at the front, it offers something new that others do not support - using laser to do auto focus
Battery is rated at 3000mAh...
The self healing back of the LG G flex2 is interesting because it will help maintain the "pristine" of the device from daily wear and tear, so will the resell value be higher?
#WhyCurveWrongWay #HotCurves #SexyCurves
xtramadness
#hotcurves is available in Platinum Silver and Flamenco Red
From the website:
With no side buttons interrupting its design, the curved form factor of the G Flex2 is both easy to hold and intuitive to operate.
The uniquely curved 5.5 Full HD Display delivers more immersive and lifelike viewing experience. The curved display phone creates optimal viewing angles to minimize glare and reflections.
Always look your best with instant Self Healing Technology that naturally fixes scratches and blemishes to help your G Flex2 maintain its timeless look.
Capture photographer quality shots with LG’s superior OIS+ that steadies every shot for sharp focused images. And with Touch & Shoot you can touch anywhere on the screen to capture stunning images in an instant.
GESTURE SHOT & GESTURE VIEW
- No more stretching out your arm and struggling to press the shutter button. Take a better selfie without pushing any buttons by making a simple hand gesture.
- Instantly see your latest selfie creation as the Gesture View feature opens your photo gallery as soon as you lower your G Flex2 camera from position
Find the power you demand to multitask at blazing speeds with the Qualcomm Snapdragon 810 processor with (integrated) 64-bit Octa-Core CPU and today’s latest Android OS.
Spend less time charging and more time doing what you love with accelerated charging that refuels 50% of the battery in about 30 minutes.
Conserve battery power and time with Glance View. Check the time and other notifications while the screen is off simply by dragging down on any part of the screen.
Check out the smartphone options offer a wide range of features, such as 3D technology, Wi-Fi Hotspot, IPS displays and more.
xtramadness
#‎LGMobilePhotography
#LGGFlex2
#whyedgehalfway
#LGHotCurves
#LGsexycurves
#LGCurves
What else hash tag is there?
jtec14
I thot local combination is 2gb ram with 32gb internal memory? SG won't get 3gb ram version for sure but got 16gb internal memory version?
xtramadness
Well, its still just a variation in the model available....
jeff79
Will the curved shape of the flexible LG G flex 2 help to protect the screen from being dropped on floor?
jeff79
Will laser emit radiation, harmful to user?
Should be safe as LG G3 using the same laser focus as LG flex 2 was approved for sale around the world. Read that eye and skin can adsorb some amount of infra red laser.
jeff79
Hopefully, had a moment too short with LG Gflex 2 demo to judge the differences from amoled. Read in the mentioned link, that plastic substrate can't stand high temperature, and LG Display developed a more stable one based on PI/polyimide with chemical stability. Probably precaution against the heat issue for Qualcomm Snapdragon 810??
Saw video review of samsung s6 edge which should be also using plastic substrate. The screen was heated with lighter flame for some time which caused colours to change at the spot that was heated then gradually return to normal as the screen cooled. Maybe Hardwarezone can conduct this test on curved LG G Flex 2 POLED screen.
jeff79
can start investing on rugged phone design instead of nice slim design...if there ish a market for it.......:(:(
Other brand had active version of the flagship phone that was more rugged but with lower spec for few years already. Seem like is small niche segment as not many brands come out with rugged phone.
jeff79
Samsung's 14nm chip good until apple must Uturn ask samsung manufacture for them once mention wanna stop give samsung business
Even AMD is rumoured to use 14nm chip for the next generation of graphic cards. Hope really true, as graphic card is stuck in 28nm for years and not much performance increase.
Maybe LG can also use samsung 14nm technology to manufacture their next generation of mobile processor LG NUCLUN for next year LG G5 and LG Flex.
http://www.lgnewsroom.com/newsroom/contents/64743
dawnmorra
lower spec not for gamers ma.
xiaowhois
must have competition than will improve mah if not much competition just maintain current technology and they can earn more profit margin.
only if LG learn from samsung make their own cpu for their G flex or G series phones
xiaowhois
the demand for rugged/active phone not that much that why you dont see apple sell rugged iphone or sell LG Gflex 2 rugged version
