xtramadness
- Mar 4, 2009
The LG Flex 2 gives and provides an ergonomic hold on the phone which should sit pretty comfortably on your palm. Together with its large crisp 5.5" screen that sports a 1080p resolution and coupled with 2GB or 3GB ram, 16gb or 32GB of internal memory respectively, it has pretty much everything that an average user needs to run his stuff daily on a phone.
Including the of up to 128gb microsd for expandable memory (well, funny because 200gb is now out), you can carry all your memories together
Why the twin model with 3GB ram and 32gb internal memory or 2GB ram and 16GB internal memory might be puzzling but probably costs?
It will be running on the latest Android OS - Lollipop
POLED in Full HD 1080p screen, resulting in a resolution of 403ppi.
The screen is protected by Dura-Guard Gorilla Glass 3
With the heart powered by the latest Qualcomm Snapdragon 810 quad-core processor running 2Ghz, it also supports native 64bit processing
OIS+ on the 13 MP (megapixel) camera for the back (rear) with 4K high-resolution video recording and 2.1 megapixel at the front, it offers something new that others do not support - using laser to do auto focus
Battery is rated at 3000mAh...
The self healing back of the LG G flex2 is interesting because it will help maintain the "pristine" of the device from daily wear and tear, so will the resell value be higher?
#WhyCurveWrongWay #HotCurves #SexyCurves
