Best VPN provider (In your opinion)? (Strictly no referral allowed)
Wongpk
i subscribe to Unotelly DNS how come i cannot watch Australia movies
i can't VPN to australia and watch these 600 movies FOC ? can you
http://www.sbs.com.au/ondemand/list/movies/genres/all-genres?cid=infocus
hnzfaz
Can anyone help me with Astrill.
When I use sg 2 or sg 1 server to surf with firefox, quite often, many sites cannot load or load fully, or takes a very long time to load. When I toggle off the VPN, then those sites have no problem loading.
Anyone else experience similar problem? What I can do to reduce the problem. Btw I'm on singnet.
Soccer Ball
Suspended
Try with chrome. If chrome can means likely firefox got problem. Reinstall firefox
oric1
I've just tested SG1 & SG2 with Firefox, no problem & loading was fast for all sites visited on Starhub fibre. Maybe you want to try uninstalling & reinstalling your VPN client.
congster2
What kind of device are you using to watch the channel? Are you using VPN or DNS? Are you connecting to the right servers?
You need to know what best suits your purpose before you sign up for a dns/vpn service.
If you are looking to change IP addresses, you most likely will need VPN, whereas if you are just looking to access specific content in certain territories, then DNS is also a viable option (usually cheaper). Many service providers offer both options but not all (e.g. Astrill doesn't offer DNS).
To access content within certain territories, you should also pay attention to where the servers are. For instance, if you want to access Aus content, you should try to see if there is a server in Aus.
Unotelly doesn't have a VPN server in Aus but they do have DNS servers there. Their VPN servers are in US (no torrenting), UK, Netherlands, Canada, and Germany. Not that many. I don't consider them strong in VPN. As their servers aren't that near to us, you shouldn't expect terrific speeds. I happen to need both DNS and VPN services and am able to tolerate slower speeds for VPN, for a lower price*, so unotelly works for me. It might not work for you.
*DNS+VPN = $7.65 USD, but after a discount, it is about USD 4 bucks for this month's subscription. I'm trying out a month first. I also tried Cactus which was faster VPN wise but slower for DNS. DNS speed is critical for me because I need it for live HD streaming. I can tolerate slower VPN speeds as Im prepared to wait a little longer.
I think it is also important to be mindful that different solutions are easier to implement for different devices.
For instance, on my Sony TV and PS3, I can change the DNS server in a jiffy so a DNS solution is more elegant if im interested in netflix. Conversely if i wanted to implement VPN, i would either have to
(i) mount VPN on the router itself (could be more troublesome and there are limitations as often 3rd party firmware flashing is necessary, e.g. asus-merlin wrt, and this is not supported on all routers,e.g. my asus RT-AC56S does not support this), or
(ii) connect the tv/ps3 to my PC via network cards to allow the devices to tap on the PC's VPN connection.
Perhaps there are other solutions, but I have not come across any thus far after doing some web searches.
Even when it comes to mounting VPN, the steps vary for different protocols - OpenVPN versus PPTP/L2TP, etc. I'm interested in mounting VPN on my synology NAS and it was more troublesome to mount the OpenVPN compared to PPTP. For the latter, a simple setup using server address, userid, and password sufficed. For Astrill OpenVPN with the NAS, apart from server access settings, I had to rip a separate certificate file and telnet the .ovpn file to the appropriate folder within the NAS. I don't imagine those born after the MS-DOS era to be comfortable with performing tasks in the command prompt environment, even though one would argue the commands needed for this is relatively simple.
Bottom line - you just have to take some time to learn these things in order to handle this comfortably. No easy way out.
Mecisteus
its definitely nothing to do with your browser.
try switching the options. ie tcp/udp and ports.
hnzfaz
Turns out that my firefox noscript plugin is the culprit...
After reading a suggested solution by Soccer Ball, I tried loading the problematic sites I've had on firefox with Chrome. Surprisingly Chrome loaded those sites quickly without a hitch.
I then tried to disable some major plugins on firefox, and was able to narrow down to noscript addon. Once noscript is disabled, the sites are able to load normally. As to why it could be causing the conflict when vpn is turned on, I don't have the slightest idea.
I've uninstalled noscript but have to think of another way to protect myself from malicious javacripts. :)
Thanks bro for all the suggestions. :)
bojangle
thinking of signing up to Astrill, but the sign up is not anonymous at all which you need to fill up names, address, mobile etc?
is there other way to sign up?
Wongpk
anyone knows how much is the Unotelly UnoDNS premium plan for half year in SGD ?
nez
What is recommended for torrenting? As in reduce the likelihood of being identified?
Wongpk
anyone knows how much is the Unotelly UnoDNS premium plan for half year in Sing Dollars ?
Wongpk
wongminmin you are right i was bill $37.05 i going to change CC soon
wongkc
I did a speed test on Astrill... best US server was US LA1... but ping was 150+ and speed 1,300kb/s...
is this normal?
oric1
is this normal?
Your speed seems abit slow.
My random tests on some US servers:
LA1 ping 176, speed 3,277kB/s
Fremont ping 203, speed 12,486kB/s
Phoenix 1 ping 191, speed 13,204 kB/s
Phoenix 2 ping 256, speed 14,566 kB/s
lala81
Sorry. I'm thinking of using Astrill VPN with a synology NAS as well.
I only want to use the NAS to climb bukit timah with the VPN. Is it difficult to set up?
XxlwAteRzlxX
