More unrevealed features other than the below?
13MP ADVANCED CAMERA WITH LG SUPERIOR OIS+
LASER AUTO FOCUS
GESTURE SHOT - SELFIE TAKING WITHOUT PUSHING ANY BUTTON
GESTURE VIEW
GLANCE VIEW
ANDROID 5.0 LOLLIPOP
KNOCK CODE
Oh, and fast charge.
..if manufacturer can product phone with curved tempered glass screen do u think a problem for third party to come out the same glass screen protector ?
The LG Flex 2 gives and provides an ergonomic hold on the phone which should sit pretty comfortably on your palm. Together with its large crisp 5.5" screen that sports a 1080p resolution and coupled with 2GB or 3GB ram, 16gb or 32GB of internal memory respectively, it has pretty much everything that an average user needs to run his stuff daily on a phone.
Including the of up to 128gb microsd for expandable memory (well, funny because 200gb is now out), you can carry all your memories together
Why the twin model with 3GB ram and 32gb internal memory or 2GB ram and 16GB internal memory might be puzzling but probably costs?
It will be running on the latest Android OS - Lollipop
POLED in Full HD 1080p screen, resulting in a resolution of 403ppi.
The screen is protected by Dura-Guard Gorilla Glass 3
With the heart powered by the latest Qualcomm Snapdragon 810 quad-core processor running 2Ghz, it also supports native 64bit processing
OIS+ on the 13 MP (megapixel) camera for the back (rear) with 4K high-resolution video recording and 2.1 megapixel at the front, it offers something new that others do not support - using laser to do auto focus
Battery is rated at 3000mAh...
The self healing back of the LG G flex2 is interesting because it will help maintain the "pristine" of the device from daily wear and tear, so will the resell value be higher?
#WhyCurveWrongWay #HotCurves #SexyCurves[/QUOTE
actually lollipop not that good for power users
they disable mobile toggle which was on kitkat
The industry is moving towards smaller and more densely packed processor. Snapdragon 810 is 20nm, Exynos 7 is 14nm. 14nm is supposed to be more efficient and more powerful. But with it getting smaller there might be issues with dissipating heat especially in a mobile phone. 14nm is pretty much state of the art now for mobile devices, and next year qualcomm snapdragon 820 will be using 14nm too.
I don't think even computer processors have 10nm yet? lol. The upcoming Skylake still using 14nm. from what i know.
LOL...just search Qoo10, really got glass protector that can bend.
Hope they release one for the LG G Flex 2 soon.
does it break easily~?BTW anyone signed for the LG G4 trial and gotten any responses?
In case anyone ask where to sign up, I saw it in the pop up box on the right of the screen wor.
#LGG4
#TRYTHEGREAT
trial for LG G4 need write review or sexpose face~?THE FLEX what we can expect?
Even AMD is rumoured to use 14nm chip for the next generation of graphic cards. Hope really true, as graphic card is stuck in 28nm for years and not much performance increase.
Maybe LG can also use samsung 14nm technology to manufacture their next generation of mobile processor LG NUCLUN for next year LG G5 and LG Flex.
http://www.lgnewsroom.com/newsroom/contents/64743
LASER AUTO FOCUS
GESTURE VIEW
GLANCE VIEW
KNOCK CODE
Need to do review and post in your facebook and/or Instagram.
#hotcurves
#whyedgehalfway
#LGGFlex2
#LGMobilePhotography
Maybe the tempered glass protector is specially made for the LG G Flex 2, so bendable ?
#LGGFlex2
#whyedgehalfway
#LGHotCurves
#LGsexycurves
#LGCurves
