What The Flex can the LG G Flex2 do?
mosmos
High Honorary Member
Does anybody know if a heavy load on the LG G Flex 2 is removed only after a long time, will it be able to flex back to its original curve ?
Maybe koon time under body for 6-8hr will bend?
#LG #hotcurves #whyedgehalfway #LGGFlex2 #LGMobilePhotography #SELF HEALING TECHNOLOGY #13MP OIS+ Laser AF CAMERA #5.5" POLED #Qualcomm Snapdragon 810 #lollipop #PLATINUM SILVER AND FLAMENCO RED #knock knock code
jtec14
I owned LG G3 over a year now , its now time to get a LG G4. I used to be a samsung fan but LG changed it all through LG InnovatIon. I got used to its back volume rocker and power key and it feels nice. Also the double tap for standby and turn on the screen is the BEST. I LOVE LG. LG rocks!!!
Not sure how easy to get used to the power and volume keys at the back, is it awkward?
New LG G Flex2 Bringing Sexy Back, PLATINUM SILVER AND FLAMENCO RED
#whyedgehalfway
#HotCurves
#‎LGMobilePhotography
#WhyCurveWrongWay
#SexyCurves
Can withstand 25kg load, flexible, bendable.
jtec14
How is the POLED screen in the LG G Flex 2 compared to other screens ?
#LGGFlex2
#whyedgehalfway
#LGHotCurves
#LGsexycurves
#LGCurves
Between POLED and AMOLED, so far only differences I noted is the brightness and the former being flexible.
#whyedgehalfway
#HotCurves
#WhyCurveWrongWay
#SexyCurves
#SexyBack
jtec14
I think the LG G Flex 2 isn't touted for the physical punishment features... maybe some unique software features or the camera features like the IOS+.... :o
LG G Flex 2 for physical punishment??? :s22: SM huh???
But the 3000 mAH non removable battery juices seems not adequate..
mosmos
From GSMarena
Web browsing for the LG G Flex 2 is lower than expected.
otherwise, battery wise can be considered an all rounder.
Omg thats bad, with large battery LG flex G2 should last more than 10hrs
mosmos
I wonder how well LG Flex 2 POLED performance under bright sunlight?
#whyedgehalfway
#HotCurves
#WhyCurveWrongWay
#SexyCurves
#SexyBack
mosmos
Yes glass protector definitely easier to apply and better than plastic.
To WhiteAnt, that seems to be a rather fragile glass your sis got. Anyway better let the glass protector absorb the damage rather than the screen but I do have friends who had rather major accidents that both protector and screen cracked.
Wonder the glass screen protector will crack if the LG G2 flex was to bend?
cstanhwz
#whyedgehalfway
#HotCurves
#WhyCurveWrongWay
#SexyCurves
#SexyBack
According to GSMarena "Under direct sunlight, the LG G Flex2 is able to retain excellent contrast and stay legible even in the most brightly lit environments".
#hotcurves
#whyedgehalfway
#LGGFlex2
‪#‎LGMobilePhotography‬
#5.5" POLED
#lollipop
#knock knock
Nakedtoes
#whyedgehalfway
#HotCurves
#WhyCurveWrongWay
#SexyCurves
U will get use to it quite fast ;)
jtec14
QUOTE=xtramadness;93452117]The LG Flex 2 gives and provides an ergonomic hold on the phone which should sit pretty comfortably on your palm. Together with its large crisp 5.5" screen that sports a 1080p resolution and coupled with 2GB or 3GB ram, 16gb or 32GB of internal memory respectively, it has pretty much everything that an average user needs to run his stuff daily on a phone.
Including the of up to 128gb microsd for expandable memory (well, funny because 200gb is now out), you can carry all your memories together
Why the twin model with 3GB ram and 32gb internal memory or 2GB ram and 16GB internal memory might be puzzling but probably costs?
It will be running on the latest Android OS - Lollipop
POLED in Full HD 1080p screen, resulting in a resolution of 403ppi.
The screen is protected by Dura-Guard Gorilla Glass 3
With the heart powered by the latest Qualcomm Snapdragon 810 quad-core processor running 2Ghz, it also supports native 64bit processing
OIS+ on the 13 MP (megapixel) camera for the back (rear) with 4K high-resolution video recording and 2.1 megapixel at the front, it offers something new that others do not support - using laser to do auto focus
Battery is rated at 3000mAh...
The self healing back of the LG G flex2 is interesting because it will help maintain the "pristine" of the device from daily wear and tear, so will the resell value be higher?
#WhyCurveWrongWay #HotCurves #SexyCurves
i read somewhere is gorilla glass 4 right?[/QUOTE]
I read GORILLA GLASS 3 WITH DURA GUARD COATING leh
WhiteAnt
LG has 6.16h for Web browsing which you guys mentioned is low. What's the average time?
#‎LGMobilePhotography #LGGFlex2 #whyedgehalfway #LGHotCurves #LGsexycurves #LGCurves #whyedgehalfway #HotCurves #‎LGMobilePhotography #WhyCurveWrongWay #SexyCurves #SexyBack
Alexz_Hong
Let's see. Based on tests from the same site, the LG G2 which is a much older phone with 3000mAh battery too lasts, 11:43h. The 1st LG G Flex lasted 9:31h with 3500mAh battery.
Other flagship devices:
HTC One M8 (12:29h) 2600mAh
Samsung Galaxy S6 (10:56h) 2550mAh
Sony Xperia Z3 (12:03h) 3100mAh
Sony Xperia Z3 Compact (14:52h) 2600mAh
The LG G3 didn't have a great web browsing battery life too. Slightly better than the G Flex 2 only at 6:29h.
http://www.gsmarena.com/battery-test.php3
