ASUS Zenfone 2
tiger2013
So has anyone tested the GPS? What's its general accuracy level like?
wlbwlb
Hi guys, those who have the phone already, how the performance for the 2gb ram version?
Better to wait for the 4gb ram version?
kyiori
Personally I think 2gb ram is enough unless you are a power user who multitask.
i'm using 550
it's ok for me, the letdown is the sheer amount of useless apps inside the phone.
hope to install pure AOSP this phone will rock.
qippiq
Suspended
It's not about vibration on touch, that one i disabled le. It's the whole vibration when whatsapp/call/message comes in.. I notice the phone does not have a way to entirely disable vibration or the intensity (i'm using samsung previously, it had that function)
have you found any solution to this? i just got the phone about an hour ago and already this vibration on whatsapp notification is annoying me.
kyiori
You need to go into the app and select option > notification to disable it manually for now. Not sure if asus will provide an update to resolve the lack of vibration setting in the UI.
qippiq
Suspended
brilliant. that's of great help.
coyote
