What The Flex can the LG G Flex2 do?
zenify.me
:s22: seems like better~
# hotcurves
# whyedgehalfway
# LGGFlex2
# LGMobilePhotography
# SELF HEALING TECHNOLOGY
# 5.5" POLED Dura-Guard Gorilla Glass Full HD 1080p
# 13MP OIS+ Laser AF CAMERA
# Qualcomm Snapdragon 810 Adreno 430 Android Lollipop
# PLATINUM SILVER OR FLAMENCO RED
# KnockOn KnockCode
dedicated device always better than all in one:s22:
zenify.me
for ladies to act cute lol. the clench your fist is their gesture shot for easy photo taking especially selfie. they also have gesture view in which you lower the phone after photo taking and it will take you to gallery.
#hotcurves – easy to hold and operate without the need for side buttons
#whyedgehalfway – It is better to curve all the way
#LGGFlex2 – Latest flex phone from LG
#‎LGMobilePhotography - Take photo anywhere with your LG G Flex 2
#SELF HEALING TECHNOLOGY – self healing technology to fix minor scratches and blemishes
#13MP OIS+ Laser AF CAMERA – touch and shoot on the screen to take steady and amazingly sharp and focused professional photos with optical image stabilisation
#5.5" full HD curved POLED – provide optimal viewing with great depth, contrast and colours
#Qualcomm Snapdragon 810 – Powerful octa-core 64bit CPU for next generation Android and apps computing
#lollipop – latest and greatest Android 5.0.x
#accelerated charing - charge to 50% in about 30 minutes
#PLATINUM SILVER AND FLAMENCO RED – Erm…Why no white?
#knock knock – Who’s there? Most ingenious way to wake your phone
#at least 50KG – withstand 50Kg or more abuse without giving way. Provided the phone is placed on the floor lol
#GESTURE SHOT & GESTURE VIEW - simple hand gesture to take photo. Gesture view display photo gallery automatically when LG G Flex2 is lowered from position
some ladies no need act cute liao leh :s22:
Mockingjay
Cruved flexible P-OLED screen
Self-healing material back cover
Laser-guided autofocus
OIS+
Gesture Shot & Gesture View
Knock Code
Withstand 50kg pressure
Qualcomm Snapdragon 810 64-bit
Android Lollipop
All in one on LG G Flex 2 ;)
WhiteHunter
oh din hear anyone talking the cheese shutter prior to the video and he mentioned the manual so I thot not available online.
So the keywords are preset, will be good if it can be customised the keywords as I understand Motorola moto also have such feature.
don't think can customised since its fixed to the five words and the two hand gestures.
WhiteHunter
WhiteAnt
Tips of the Day:
Glance at your notifications with a down swipe on the lock screen
The G Flex 2 has a new feature called Glance view. Holding your finger on the display, and then swiping down will show weather, time, and notifications. It’s a nifty feature that allows you to preview more information. It’s good for checking notifications, but some will find that it’s just as easy to preview notifications with knock on. For those who are new to LG phones, knock on involves double tapping on your phone to get quick access to the lock screen.
#whyedgehalfway #SELF HEALING TECHNOLOGY #LGGFlex2 #hotcurves #13MP OIS+ Laser AF CAMERA #5.5" POLED #Qualcomm Snapdragon 810 #lollipop #knock knock #PLATINUM SILVER AND FLAMENCO RED #lollipop #SexyCurves #LGG4camera #LaserFocus #WhyCurveWrongWay #LGMobilePhotography
WhiteHunter
Got crackling sound! :s13:
But it bends back and perfect ok. :o
#LG #LGG4 #LGGFlex2 # 5.5" POLED Dura-Guard Gorilla Glass Full HD 1080p #Qualcomm Snapdragon 810 Adreno 430 Android Lollipop
wonder what broke when there's crackling sound but the phone still can work.
WhiteAnt
The plastic sound I think :o
But got sounds means something is tearing, so probably needs a deeper inspection.
jeff79
Overheating phone are common. Especially with 4k video only can take for a few minutes before it will force shut down. Do LG g flex 2 have this in place also?
Sent from behind your back using GAGT
According to review, LG G Flex2 is limited to 5 minutes when recording 4K video. The time limit is not due to just heat management. Some phones can record 4K without heating much but also have 5 minutes limit to prevent using up the storage. Most phone record 4K video at 1GB per minute, can easily use up all storage space.
jeff79
scratch test for LG Flex G2 looked not very healable~
# hotcurves
# whyedgehalfway
# LGGFlex2
# KnockOn KnockCode
This scratch test using knife is too extreme. The self heal material on LG G Flex 2 curved back cover is just a thin layer for scratches from normal wear in pocket or on table.
xtramadness
he keywords are Cheese, Smile, Whiskey, Kimchi and LG
SHe used palm and fist for selfie
#LGGFlex2
#youcanfindthese
#what the flex
#flexible
#bendable
#selfie
#Plastic-OLED
#P-OLED
#Self-healing technology
#Laser-guided autofocus
#OIS+ Camera
#Gesture Shot
#Gesture View
#Knock Code
#Adreno 430
#Android Lollipop
#Quick Charge 2.0
jeff79
Wow the LG G Flex 2 can be dropped into water and survive.
But won't the water get into the holes like the USB charging port, the headphone port and damage the phone ?
The video only show the LG G Flex 2 still working right after out of water. The water that seeped into the interior will slowly corrode the copper contacts and components, problem will appears much later. Most phones even water resistant model have wet indicators inside that will void warranty when they changed colour.
jtec14
No, I downloaded the user guide for the LG G Flex 2 and found the cheese shuttle command.
Cheese, Smile, Whiskey, Kimchi, or LG.
Just wondering, is it really voice command or facial thing?
All these words end with a smile on your face.
So I guess it is actually detecting the smile on your face then take the picture?
If so, it is just a smile shutter like what Samsung had since S4.
Only way to determine whether voice commands or not , is when they allows customised keywords assuming a firmware update allow that.
xtramadness
#hotcurves is available in Platinum Silver and Flamenco Red
From the website:
With no side buttons interrupting its design, the curved form factor of the G Flex2 is both easy to hold and intuitive to operate.
The uniquely curved 5.5 Full HD Display delivers more immersive and lifelike viewing experience. The curved display phone creates optimal viewing angles to minimize glare and reflections.
Always look your best with instant Self Healing Technology that naturally fixes scratches and blemishes to help your G Flex2 maintain its timeless look.
Capture photographer quality shots with LG’s superior OIS+ that steadies every shot for sharp focused images. And with Touch & Shoot you can touch anywhere on the screen to capture stunning images in an instant.
- No more stretching out your arm and struggling to press the shutter button. Take a better selfie without pushing any buttons by making a simple hand gesture.
- Instantly see your latest selfie creation as the Gesture View feature opens your photo gallery as soon as you lower your G Flex2 camera from position
Find the power you demand to multitask at blazing speeds with the Qualcomm Snapdragon 810 processor with (integrated) 64-bit Octa-Core CPU and today’s latest Android OS.
Spend less time charging and more time doing what you love with accelerated charging that refuels 50% of the battery in about 30 minutes.
Conserve battery power and time with Glance View. Check the time and other notifications while the screen is off simply by dragging down on any part of the screen.
Check out the smartphone options offer a wide range of features, such as 3D technology, Wi-Fi Hotspot, IPS displays and more.
xtramadness
Of all the #LG #hotcurves #whyedgehalfway #LGGFlex2 #‎LGMobilePhotography #selfhealingback #LaserAFCAMERA #POLED #Qualcomm #Snapdragon #lollipop #Platinium #Silver #Flamenco #Red #platinumsliver #flamencored my favourite is still the #leather #back
jtec14
Tips of the Day:
I am surprised they did not make use of sensors, wake by waving in front of the phone. As for swipe down for notifications isn't it inbuilt for android?
