What The Flex can the LG G Flex2 do?
jeff79
But reports say the Snapdragon 810 in LG G Flex 2 overheats easily and will be throttled. Thus the performance might not be better than the LG G4.
LG G Flex 2 seems to be marketed for the ladies who be drawn to its sexy curved design.
LG G Flex2 screen resolution is lesser at 1080p than LG G4 1440p, the processor is able to do less work. Even when throttled has better frame rate and performance.
MoneyFace =p
With Android Lollipop and Qualcomm Snapdragon 810, curved P-OLED display, self-healing material back cover, Laser autofocus and OIS+ camera, Gesture Shot and Gesture View, Knock Code technology. LG G Flex 2 makes a great unique phone of its own...
mosmos
High Honorary Member
:s22: your post like everyday same one~
xtramadness
The keywords are Cheese, Smile, Whiskey, Kimchi and LG
SHe used palm and fist for selfie.
LGGFlex2 people will say what the flex as it is flexible bendable great for selfie
Screen powered with a Plastic-OLED or P-OLED back with Self-healing technology
Camera empowered with Laser-guided autofocus, OIS+ Camera, Gesture Shot, Gesture View and Knock Code
xtramadness
The LG Gflex2 hotcurves is available in Platinum Silver and Flamenco Red
From the website:
With no side buttons interrupting its design, the curved form factor of the G Flex2 is both easy to hold and intuitive to operate.
The uniquely curved 5.5 Full HD Display delivers more immersive and lifelike viewing experience. The curved display phone creates optimal viewing angles to minimize glare and reflections.
Always look your best with instant Self Healing Technology that naturally fixes scratches and blemishes to help your G Flex2 maintain its timeless look.
Capture photographer quality shots with LG’s superior OIS+ that steadies every shot for sharp focused images. And with Touch & Shoot you can touch anywhere on the screen to capture stunning images in an instant.
GESTURE SHOT & GESTURE VIEW
- No more stretching out your arm and struggling to press the shutter button. Take a better selfie without pushing any buttons by making a simple hand gesture.
- Instantly see your latest selfie creation as the Gesture View feature opens your photo gallery as soon as you lower your G Flex2 camera from position
Find the power you demand to multitask at blazing speeds with the Qualcomm Snapdragon 810 processor with (integrated) 64-bit Octa-Core CPU and today’s latest Android OS.
Spend less time charging and more time doing what you love with accelerated charging that refuels 50% of the battery in about 30 minutes.
Conserve battery power and time with Glance View. Check the time and other notifications while the screen is off simply by dragging down on any part of the screen.
Check out the smartphone options offer a wide range of features, such as 3D technology, Wi-Fi Hotspot, IPS displays and more.
xtramadness
I prefer the flemenco red with a sexy leather back. Oh I miss leather back... But... Still leather :love:
xiaowhois
The LG G Flex 2 comes in platinum silver also .... not just flamenco red.
Yes, I can relate to that.
Still remember paying $210 for 512MB for a Lexar Memory Stick some years ago.
And it was considered cheap for a 512MB Memory stick.
Now a 4GB microSD is less than $5!!!
At the moment 64GB microsd sd most worth and value to put inside Lg g flex 2. 64 plus 32 around 70GB of user storage for lg gflex 2
WhiteHunter
:s11: laser auto focus a gimmick~?
Part of the G3 camera's appeal and now the G Flex 2 is its laser-based autofocus. It lets you take quick shots, by simply tapping the point of the screen that you want in focus.
OIS+ to help offset the effects of shaky hands.
WhiteHunter
The most significant feature of the G Flex series is arguably its ability to 'self-heal'.
LG G Flex2 protected by DuraGuard Glass and a unique 'self-healing' back cover, boasts a quicker healing time diminishing light scuffs and minor grazes within seconds under room temperature of 27 degrees and above.
The precise curve of the 5.5" full HD P-OLED display brings about minimal glare and gives you an optimal viewing angle from all directions for a truly immersive viewing experience. The steeper curvature on the back will have your fingers wrapped perfectly around the device allowing for a better grip and fit.
First among all smartphones to be powered by the new Snapdragon 810 processor, this powerhouse device will give you the sizzling speed and jaw dropping graphics you desire with its octa-core 64-bit capable CPUs 0 and the advanced Qualcomm Adreno 430 GPU.
xiaowhois
Snapdragon 810 used in LG G flex 2 still have some issues that why new LG G4 dont use Snapdragon 810 like LG Gflex 2 but they use Snapdragon 808
instead.
mosmos
instead.
:s22: maybe cost issue for Snapdragon 810 used in LG G flex 2 so use Snapdragon 808~?
mosmos
LG G Flex 2 though had built in non-removable battery but this video shows easy to replace the battery~
koreanlover
This video shows LG G Flex, not LG G Flex 2 ?
But the process should be the same.
Is the battery curved like the phone too ?
koreanlover
instead.
If they knew about the issues in 810, why didn't LG use 808 for LG G Flex 2 too ?
Hopefully LG releases a software update to help reduce the problem in 810.
