AMD R9 290x VS GTX 980
koroshiya8
actually can get 290x first then later when 3xx come out, sell it and reconsider the options.
Nitrile
980 for most eye candy at 1080p
if you want a space heater go for 290x :s13:
k8118k
Budget - r9 290x hdmi 1.4 max output FHD@60ghz.
cons - heat up the room temp
Premium - gtx980 hdmi 2.0 max output UHD@60Ghz.
Jian19
tri x and lightning series 290x have agressive cooler and temps are good
but they look like giant , freaking big and long
Mikiberry
74 degrees under native 4k gaming max load. Solid card. But I bought for CF which is bad. VRM cant be cooled efficiently, else I would have continue to use them to support my 4k rig.
aptget
Test results show overwhelming win for 980, at twice the price
yea at TWICE the price, and performance is NOT twice
I would still go with 290x, or hold out for the newer cards like others said.
trento
But nvidia always command a premium. They have fanboys, er i mean fanbase.
Ark Law
Aiyah, just get the cheapest GTX970 from Lazada (using $50 discount code) for now. When the next big thing comes, can get the new model and sell away the 970 with minimal wallet pain
Fatfool
Aiya very simple.
the 290X performs at 70% of a GTX980, costs about 50% of a GTX 980 and has a TDP of about 150% of the GTX 980.
If TS is concerned about minimising costs, get the 290X
If the TS is concerned about maximising performance for a fixed budget, get Crossfired 290X
If TS is concerned about heat/energy, or if TS is using a Small form factor machine get the GTX980.
Done! NEXT!
trento
Aiya very simple.
Done! NEXT!
In short, don't get 970!
avsquare
The 970 isn't that bad if you consider price-performance ratio tho.
My 970 benchmarked higher than my 290 (note, non X) for a start and just trail the 290X by very little
And the 970 SLI, depending on which game and benchmarks you are using, the 970 SLI wins the 295x2 on some, but loses on some, but the win/losses in these scores aren't too much.
In a sense, you are paying less than half the price of a 295x2 but getting the same performance with lesser power draw.
Here's a review: http://www.guru3d.com/articles_pages/geforce_gtx_970_sli_review,1.html
