What The Flex can the LG G Flex2 do?
dawnmorra
The LG Gflex2 hotcurves is available in Platinum Silver and Flamenco Red
From the website:
With no side buttons interrupting its design, the curved form factor of the G Flex2 is both easy to hold and intuitive to operate.
The uniquely curved 5.5 Full HD Display delivers more immersive and lifelike viewing experience. The curved display phone creates optimal viewing angles to minimize glare and reflections.
Always look your best with instant Self Healing Technology that naturally fixes scratches and blemishes to help your G Flex2 maintain its timeless look.
Capture photographer quality shots with LG’s superior OIS+ that steadies every shot for sharp focused images. And with Touch & Shoot you can touch anywhere on the screen to capture stunning images in an instant.
GESTURE SHOT & GESTURE VIEW
- No more stretching out your arm and struggling to press the shutter button. Take a better selfie without pushing any buttons by making a simple hand gesture.
- Instantly see your latest selfie creation as the Gesture View feature opens your photo gallery as soon as you lower your G Flex2 camera from position
Find the power you demand to multitask at blazing speeds with the Qualcomm Snapdragon 810 processor with (integrated) 64-bit Octa-Core CPU and today’s latest Android OS.
Spend less time charging and more time doing what you love with accelerated charging that refuels 50% of the battery in about 30 minutes.
Conserve battery power and time with Glance View. Check the time and other notifications while the screen is off simply by dragging down on any part of the screen.
Check out the smartphone options offer a wide range of features, such as 3D technology, Wi-Fi Hotspot, IPS displays and more.
The Wi-Fi Hotspot very cause can share devices to data.
cstanhwz
The LG G Flex 2 (about to hold 25KG to 50KG) has a 13MP OIS+ Laser AF CAMERA and you can touch and shoot on the screen to take steady and amazingly sharp and focused professional photos with optical image stabilisation. The laser AF should help the LG G Flex 2 to focus better in low light.
cstanhwz
The LG G Flex 2 comes in flamenco red and platinum silver.
The cheese shuttle uses Smile, LG, Cheese, Kimchi and Whiskey as command.
cstanhwz
Not a pro but I think lighting play a part for all cameras. With poor lighting, there always a limitation how good the picture will turn out.
Think the laser AF is supposed to help focus better or faster or easier in poor light for the LG G Flex 2
cstanhwz
heat issue is the most problematic because heat will kill LG G flex 2's electronic parts
Yes heat is the enemy for electronics like the LG G Flex 2.
Especially it is using the Snapdragon 810 cpu which is known for overheating issue.
Gaiason
The keywords for taking photos used are Cheese, Smile, Whiskey, Kimchi and LG
SHe used palm and fist for selfie.
LG G Flex2 people will say what the flex as it is flexible bendable great for selfie
Screen powered with a Plastic-OLED or P-OLED back with Self-healing technology
Camera empowered with Laser-guided autofocus, OIS+ Camera, Gesture Shot, Gesture View and Knock Code
I prefer if they used something more cheesy for the keywords
cheesy keywords? personally dun take selfie... so tis is extra...:(:(
cstanhwz
yes but limited ppl will benefit from this campaign....dun think i can get it...:(:(
You currently 688 points. I think difficult to get the LG G Flex 2. Unless some of the current leader screw up.
Or you get bonus points and overpass them (just saying, not that will really happen hor).
Edit: Now you also 731. But your timing at 11pm later. Wasted.
cstanhwz
Just saw this news...
Xiaomi boats faster Snapdragon 810 chip inside the MiNote Pro.
"But the phone might just have another trick up its sleeve. According to Xiaomi, the MiNote Pro uses a newer version of Qualcomm's top-of-the-line chip. The SoC it has is a v2.1 model, which the manufacturer claims gives it a slight edge in performance over other phones with the same Snapdragon chip."
Maybe the v2.1 solved the heat issue.
http://www.gsmarena.com/xiaomi_boats_faster_snapdragon_810_chip_inside_the_minote_pro-news-12172.php
xiaowhois
of coz not la.....still have a tolerance level...:(:(
long term heat will cause electronic to breakdown faster lo~ maybe LG G flex 2 suffer heat issue long term when just nice 1yr warranty end it break down.
xiaowhois
they know the issues faced by LG G flex 2 maybe add extra cooling feature. Qualcomm maybe give them a better price to use Snapdragon 810 instead of Snapdragon 808
Picory0
Snapdragon say no such issue. so lg g flex 2 is still good for selfie
Picory0
LG G flex 2 good for food photograph? Got social media direct? LG give free phone. Jin song
