What The Flex can the LG G Flex2 do?
cstanhwz
Your first post now at 1244pm.
Hope you do not slip further in timing for the LG G Flex2.
Within grasp already.
Nevermind, the 2nd and 3rd spot leaser until 3pm also have not posted.
You are safe!!!
Once you get the LG G Flex2, do a review if you not selling.
koreanlover
I have Flex1 and 2, Flex 1 is quite a durable phone as I have drop at least 5 times seriously and LG Flex 1 still function well. Havent try my Flex2 durability yet.But looking at the video, it should be quite ok. However i noticed for Flex2 the phone get heated up if i continue using for hours. Not sure if it is the internal battery. My friend say is it ok de. Overall the selfie part was good experience as you can just open and close your fist on the screen, it will start 3 secs timer. This is very good when using selfie stick. Also i noticed the battery charge faster then Flex1. Last but not last i noticed after I bought all the curve phones i have no interest in straight phone anymore. Lol..
Does Flex 1 camera also have OIS+ and laser auto focus like Flex 2 ?
Have you tried playing games when your LG G Flex 2 gets heated up ? Does it lag ?
xtramadness
The keywords for taking photos used are Cheese, Smile, Whiskey, Kimchi and LG
SHe used palm and fist for selfie.
LGGFlex2 people will say what the flex as it is flexible bendable great for selfie
Screen powered with a Plastic-OLED or P-OLED back with Self-healing technology
Camera empowered with Laser-guided autofocus, OIS+ Camera, Gesture Shot, Gesture View and Knock Code
I prefer if they used something more cheesy for the keywords
xtramadness
The LG Gflex2 hotcurves is available in Platinum Silver and Flamenco Red
From the website:
With no side buttons interrupting its design, the curved form factor of the G Flex2 is both easy to hold and intuitive to operate.
The uniquely curved 5.5 Full HD Display delivers more immersive and lifelike viewing experience. The curved display phone creates optimal viewing angles to minimize glare and reflections.
Always look your best with instant Self Healing Technology that naturally fixes scratches and blemishes to help your G Flex2 maintain its timeless look.
Capture photographer quality shots with LG’s superior OIS+ that steadies every shot for sharp focused images. And with Touch & Shoot you can touch anywhere on the screen to capture stunning images in an instant.
GESTURE SHOT & GESTURE VIEW
- No more stretching out your arm and struggling to press the shutter button. Take a better selfie without pushing any buttons by making a simple hand gesture.
- Instantly see your latest selfie creation as the Gesture View feature opens your photo gallery as soon as you lower your G Flex2 camera from position
Find the power you demand to multitask at blazing speeds with the Qualcomm Snapdragon 810 processor with (integrated) 64-bit Octa-Core CPU and today’s latest Android OS.
Spend less time charging and more time doing what you love with accelerated charging that refuels 50% of the battery in about 30 minutes.
Conserve battery power and time with Glance View. Check the time and other notifications while the screen is off simply by dragging down on any part of the screen.
Check out the smartphone options offer a wide range of features, such as 3D technology, Wi-Fi Hotspot, IPS displays and more
ieDoyler
From the website:
core is 32 ?
koreanlover
The LG G Flex2 does not fit the front pocket well.
But will fit the back pocket better.
That's why it can stand 25KG to 50KG of weight...:s13:
Just make sure the phone does not drop out without your knowledge.
Yes the LG G Flex 2 will fit the back pocket better, but it is easier to drop out from the back pocket.
Will it bulge out if you put in the front pocket?
jtec14
From the website:
Actually what is the 3D technology about, can play 3d video?
koreanlover
Once again, thanks LG and HWZ for the printer! :o
Btw, I went to test a G Flex 2 from telco shop... On physical aspects, the feel is alright, bright screen and clear - no major complaints. My concern is a curvy phone might not fit into the jeans' pocket nicely and will be bulging. For the ladies, they won't have any issues since they have a handbag.
For the softwares, launching apps like camera and other basic apps lag for a few seconds. It is pretty noticeable imo, so the UI really needs improvement to push for a faster response, because the S6 isn't as bad though it lags a little bit too. I saw a lot of unnecessary apps and reminds me of samsung's old touchwiz. I wish LG will have less of those, tbh. Got 3gb ram also no need to use waste the memory like that ma :s22:
Overall, a decent phone. :) :o
No review for the photo printer?
Hope LG G Flex 2 gets updated to LG UX 4.0 soon.
