Ask a Bicycle Question - Part 5
Broadwalk
someone i know bought from a JB bike shop. they have a contact who would ship the bikes to SG for a fee.
apparently it is cheaper than if u buy in SG.
go facebook find khass
i cheapskate..
i didnt even buy dahon.
i bought a vert.
I understand from someone Vert is not reliable one?:vijayadmin:
beast
friend commented y waste 2k on a mtb to do trail when a $300 mtb can do just as well. more like paying for branding. can the 2k mtb do something which the $300 mtb cant do other than going faster thru the trail with better components
erwinrommel
agree... maybe I will consider upgrading few months later
May I know if I change from 406 to 451, what needs to be changed? Is this major?
Sort of.
You will need to change the following:
1. 451 wheelset (duh...)
2. tubes
3. tyre.. limited selection of 451 tyres compared to 406.
4. v-brake extension.. you can pm me where to get v-brake extension if you still wish to continue using your current brake system.
5. RD hanger/adapter.. if you wish to change to non Neos rear derailleur.. e.g. shimano/SRAM etc
6. FD adapter-- optional.. if you wish to add a FD
7.Change whole groupset (optional), including FD shifter, RD shifter, RD, FD, etc
likehotbutter
Yes. The tires must match the rim size, e.g. 26 inch 29inch. The tubes must match the tires, if tire 26 x 1.75, tube size also 26 x 1.75
The tube size not so important. Do you believe it if I told you that people put 26er tubes in 29ers for race if they aren't going tubeless?
Cause lighter :s13:
likehotbutter
Your friend uses hyperbole much? Supposing if the frames are the same, a 2k speced bike will be of magnitudes more capable than a $300 spec. Maybe at the 1.2-1.5k vs 2k levels (SLX onwards) that the returns start been more marginal.
Then you need to ask yourself as to what outcome and target are you looking to derive from getting into MTB.
Looking to simply explore nature on simple flat trails (Green Corridor)?
$300 mtb is fine
Looking for mostly leisure rides on PCN
$300 mtb is fine
Looking to attempt or be able to attempt more challenging local trails (Some parts of BT, gangsa, Ketam)?
Min SLX
Looking to challenge yourself physically and technically on trails?
Min SLX
Looking to ride in wet conditions
Min SLX
etc etc etc
Don't just talk about MTB. Even for road, foldies, velos, there is a clear border in the component technical specs that demarcates the minimal level of value that one should get when intending to be more serious in their involvement of the sport(Road: 105(?), MTB: SLX). Any further technical increases from that line on is mostly marginal and focuses on weight.
You need to decide where you are going to fit in this scheme of things to know what kind of bike and parts you should be spending on.
Ask your friend to bring his $300 mtb and do the black diamond on Ketam. Can be done if the rider is skilled enough. But regardless it will not be that pleasant of an experience.
Remember to video it.
rarenick
I used to have a few mtb that's $100+.
When I decided to get a good one, the minimum specs are deore parts.
The gears and shifting will be smoother, and all the parts quality are better lasting. U never heard of frames cracking/broken?
Sent from . using GAGT
Broadwalk
I ride a Vert V8 (800km in 7 months of ownership). The Vert is still in great condition. No issues so far, apart from some rusty screws.
Vert running on litepro parts? Or Cirus is using litepro? Their pricing is competitive.
erwinrommel
i cheapskate..
i bought a vert.
Khass has a pretty lady staff there. :s8:
ironsteel
Vert is okay for normal commutes and on PCN. You are not going to be able to go very fast and it's not very worth it to upgrade. But if it's just for leisure and you can get it secondhand for a good price, I think it's not a bad choice.
The shop has pretty good service too so that's a plus.
Sent from QWERTY using GAGT
beast
$300 mtb is fine
$300 mtb is fine
Min SLX
Min SLX
Min SLX
etc etc etc
Friend argued that it is all in the mind, $300 mtb not only can handle gentle trail like green corridor but other tough trails as well. It all depends on the rider. An mtb is an mtb despite the price difference. However friend does agreed that a road bike cannot handle the trail.
erwinrommel
Are you the friend? :o
Has your friend tried both MTBs? If not, how can he appreciate the difference? :s22:
beast
Friend commented that those who ride on their $3k mtb has never ride the $300 mtb before so they keep thinking it has to be inferior and there is a difference because is cheaper. Unlike for those who rode the $300 mtb and then $3k version, had to convince themselves the handling is different eventhough is the same
erwinrommel
Friend = you? :s13:
From what I see, for those who get a 3k bicycle... their first bicycle are normally $300 bicycle. That's why they are convinced to fork out 3k for their second bicycle.
For short distance, the difference is not so apparent. But when you go long distances, the difference between good and cheap bicycle will become very apparent.
Broadwalk
Just curious what hobby you have... :o
As long as you never test ride, you will never understand why bikes cost so much.
I have no hobby. I am a confused middle-age man.:o
Btw, the lady Tan really that pretty? Still single?:o
