is unotelly good for Amazon instant Video ?
It is. Smooth playback.
How come I am getting low quality amazon video using unotelly ? Is there any setting ? What is the problemIt is. Smooth playback.
Did u use the Smart DNS? Try the DN server closest to Singapore. I think there is one in Singapore itself and another one in HK. I am watching it from Amazon Fire TV and it works fine. Video quality is HD after a few seconds of loading.
Looking at VPN for torrenting. Considered Astrill but heard they keep logs and Torguard does not allow torrenting on their Singapore servers. Is this true? Anyone hitting 4-5 mbps on their VPN?
Word of caution: Never use Singapore server for torrenting if you are in Singapore even if some VPNs allow that.
Word of caution: Never use Singapore server for torrenting if you are in Singapore even if some VPNs allow that. I am sure there is more (maybe a request from SG authorities) behind AirVPN withdrawal from Singapore's Softlayer datacenter.
what about for nopremium?
Hi guys,
I've checked don't think the merlin firmware is out for the router above? So, is there a way to manually set the settings within the router page under VPN Client?
Hi Oric1,
Thanks! Guess I didnt click on the screenshot to go to the actual link coz the shot didnt have the 68 yet. Is this flash treated as an upgrade or a complete reinstall, where I have to reconfig everything again?
Thanks again. Gonna try out the Astrill.
Dear all,
Need some advise and help. And pardon for the WOT. Been reading this thread for a while and decided to get PIA vpn services for my netflix and my torrent needs. I'm on starhub fibre 100mbps plan, and im using a PC with wireless usb adapter.
I sign up the 365 days subscription. Im using utorrent at default setting. My first try was to dl the ubuntu desktop to test out. So i connected my PIA to US california server, the avg was 1.5-2mb/s and it took around 20min to dl the file (1gb). But without VPN, i can get it in less then 8min. So i did a speedtest on a few US server and other server on PIA website with VPN on,
California ~2mb/s
US east ~ 1mb/s
US west less then 1mb/s
US seattle less then 1mb/s
Hongkong 8mb/s
Singapore ~20mb/s
So i chat with the CSO and he/she told me to change my port number from 9201 to 8080 to 53 and so on, and also change from udp to tcp if the above did not work out for me, none of this improves the speed.
Then i try adding the PIA extension/exclusion on my anti virus, and also add in a DNS on the tcp/udp v4 thing on my network, also no improvement. I also tried using transmission for windows in case the torrent speed is fine just that the speed test is not, still, no improvement. I've send out another ticket seeking for help from PIA. If PIA really doesnt "suits" me, i will get the refund and sign up for another VPN service.
So, just to confirm with the VPN user and experts here, based on the above i mentioned, is there something wrong with my setting? Or is there anything else i can do? Please advise. Any help is welcome and very much appreciated.
You're using wireless that's why it's slow.
@Luffy Pirate King: Does your PC not have a wireless NIC? Why use wireless usb adaptor? Unless your NIC only has N wireless and you are using AC wireless usb adaptor... but it should not matter whether it is N or AC as you are using 100Mbps plan...
If possible, try LAN connection to see whether there is an improvement, if you can use LAN connection.
@negativezero: Luffy Pirate King stated that he can DL the file in 8mins without VPN, so the wireless should be working properly, no?
8mins without VPN is slow liao. Those Ubuntu files should be done in 2-3 mins on 100mbps. It's the problem of wireless. And I suspect he doesn't even have a good wireless adapter or router.
