Sony Xperia Z3 Tablet Compact
chengsun
Then look at the white stick on the side of the box, you will see the IMEI Number there.
this is what on my box:
hush66
Picture so small. :s22::s22:
Isn't there some sticker on one of the sides of the box that says "IMEI: xxxxx", where xxxx would be your IMEI number? Or maybe the sticker is inside your box.
Edit: I think that "IDID" number is your IMEI. It should be a 15-digit number. At times, your IMEI number might not be registered in their system yet, so you may have to wait for a few days. Or you can call them and ask them to register in their system.
chengsun
paiseh, used lousy hosting.
changed
no, this is the 2 stickers that on the box
chengsun
Good, glad that you finally got your tablet registered. =:p
thanks. very happy with this tablet, replacement for my failing nexus 7 2013. got a scare when I played a mkv file though, coz no sound. later on used BS Player to play, OK now.
OnLyOnE
If you are using MX Player, you would need a custom codec plugin. Long story short, MX player developer didnt want to pay premium for a codec, hence, they excluded it since forgot which version after. So, in order for your MX player to work like before and play ALL files, you would need this custom codec plug in.
chengsun
not using MX player, but the stock sony app, Movies
spiez1
Guys if u swim with ur tablet make syre to rinse the earphone socket. Mine got green substance i had to remove so my earpiece will work
chengsun
This tablet got wireless charging function or not? I feel that I open up the cover too often (to charge and transfer data), a bit afraid that it will spoil soon due to wear and tear.
Omnia1
Nope. No wireless charging built in. However, you can get a third party magnetic charging cable (or use a dock) and you won't have to open the USB port flap so often.
Sent from Sony SGP621 using GAGT
bigbadber
Hi,
Im interested in getting the Z3 tablet.
Can you guys advise me where to get other than from Sony shops?
name me a few places please? I've totally no idea.
