Path of Exile thread, the revival
TrueBeliever_jh
playing melee is the challenge part where if your lvl or gears not good. I killed Act 2 boss in cruel and when i go to act 3 , my hp seems draining too quick and dead.. lost 5%
yup melee is actually recommended for more experience players.. since you need to understand the defensive options in the game (stack as much HP from items and from passive tree)
my first character also melee:s13:
until lvl 60 only 2k HP~:s13::s13:
TrueBeliever_jh
Well, I believe it's just due to bad combination of mods, and a mixture of game knowledge and RNG. When you mention life draining too quick, did you get hit by a bleed? Or did you get corrupting blood stacks?
By right your life should not drain very fast, unless you stack in chaos degen cloud, or you run around while being hit with bleed stacks.
corrupting blood and bleed are those effects that die die need to have a clear bleed flask~:s13:
okay lar.. we not in bloodline league.. so dun think can see corrupting blood that often~
Vulpix
Moderator
Moderator
Eh you forgot the rare mob with corrupting blood mod ah? Not only bloodline got. If you ask me, I think bloodline one at least yo can control the number of stacks. Kill 1, you get 2 stacks niah, wait it out and kill the others.
If rare mob? I cyclone through jitao 19 stacks liao. :s22:
Vulpix
Moderator
Moderator
I was shocked when you told me last season you had 2k life at level 60 :s13: Good times.
Vulpix
Moderator
Moderator
Melee does have some difficulty, but they are by far easier to gear. You can do mid-game maps with a 4L, while casters struggle if their gems not at the correct level and no 5L.
But if you use shockwave and flame totem then different story liao. :s13:
FappingKing
High Honorary Member
Melee fun leh :s34:
TrueBeliever_jh
can see the red disco balls around your character and the HP starts to drain when you move~:s13:
good times~ :D
i havent kenna the 19x stack b4~
Vulpix
Moderator
Moderator
Melee fun leh :s34:
I prefer caster, but I feel that right now casters very little way to mitigate. During beta, I got 8k EHP, 3.5k life, 4.5k energy shield. Yet when it came to mid-game maps, this pack of blue Devourers popped up, stun me, and the use of 2 of my instead heal flask also cannot counter the amount of damage.
Vulpix
Moderator
Moderator
can see the disco ball around your character and the HP starts to drain when you move~:s13:
good times~ :D
I kenna 32 stacks before with my ball lightning build, fire into 2 rare mobs with corrupting blood, cannot control because spell, and my flask to remove bleed was empty.
Needless to say I died really nicely. :(
TrueBeliever_jh
that time i didnt plan anything on HP.. jus see which nodes got sword and dmg jus go there~:s13:
Melee fun leh :s34:
yup. i was hoping with the lockstep fix it would be more awesome.. then comes this spike
i will donate you a facebreaker if i manage to find one this league
Novenics
confirm pruss chop ish bleed lol.
khroness
i always panic when i see my hp drop so fast.. press potion and run quickly.. the combat system still not flawless la, need to stop attacking before we can use other skill like leap slam or war cry.. somtime i panic, i tried to leap slam but my left mouse keep attking so can not leapslam and kiss floor instead
cancer81
Your setup needs to be looked at if you are dying to stuff that seem random to you.
the first one is your defence setup. Your enduring cry and possible CoDT->Immortal Call setup. remember 2 things.
One, if it is not physical Immortal Call will not help.
Two, if you see Immortal Call go off. You need to think defence and retreat.
Finally, staying and fight is not manly. It is the highway to quick deaths :crazy:
EDIT:
PS : Rule 1 of playing POE. LEFT CLICK is WALK. ALWAYS WALK. NO NORMAL ATTACK. EVER
FappingKing
I in a party then i see my members around i always leap right into a pack and enduring cry :crazy:
Then i realised nobody follow me then i panic eat a few pot and leap out :s13:
khroness
should have kill cam in poe. so we know how we dead.. knn the curse/bleeding icons are all on top left, who got time to see that.. hahah my eyes focus on the middle screen my hp barb only..
I always remember D3 Barbarian leap which give you temporary add armor.. feels really like GODS.. in POE feels really like normal people..
Vulpix
Moderator
Moderator
I think you got bleed. Have you heard of the bleeding sound before? If you got bleed from monsters, there will be this PSHHHHH sound like you hold your pee very long, then finally go relief yourself. :s13: You need a flask with bleeding immunity.
The 2nd scary one is corrupting blood. If you ever see red orbs orbiting your character, it means you kenna corrupting blood. Both bleeding effects become worse when you run. You need the flask to remove the bleeding.
I do not recommend CoDT Immortal Call early game honestly, you are better off keeping your charges. 7 balls gives a lot of mitigation and life regen.
