DMC_Coolie
- Feb 4, 2007
guys if i dont have the receipt for my redmi note 4g can i still go to service centre?
my screen is discoloured....
if you purchased your Note 4G in Singapore, they will most likely have your IMEI record in their system.guys if i dont have the receipt for my redmi note 4g can i still go to service centre?
Or you can get Moto E 2014 the LTE version with SD410 for just USD99 from amazon. Pretty sweet deal as far as I'm concerned.bro whats your recommendation for other same price model? i also trying to source one best value for money phone to buy for my mum...
Sent from LGE LG-D855 using GAGT
Zenfone Asus Zen 2 ZE 500CL is dual core while this is quad core, right ?
Can give me some quick pointers what I give up if I'm not on lollipop ? Being lazy to check. Thanks if anyone can help.
Amazon is selling xt1524 which supports local 4G.Has to check if USA 4G work for Singapore.
It's worth the upgrade, IMO. You get a RAM(1GB to 2GB), internal storage(4GB to 16GB), processor(32bit MTK to 64bit SD410) and Android upgrade(4.2.2 to 4.4.4) compared to Redmi 1.is it worth upgrading from redmi (1st gen) to redmi 2 enhanced? current phone is getting laggy and keep prompting no space to install new apps even though theres definitely space available
Are you ok with the lag ? Tolerable ? You can survive without installing new apps ? If both answers are yes, then no point in upgrading. Might as well wait if you can still use the phone. Prices keeps falling, so if you can wait a year, then you get better features. my2cents.
Good point. After all Redmi 2 is still on Andriod 4.4.4.
my current redmi is a backup phone that i'm using as i broke my samsung s4. after using it for a couple of months, i kind of realised that i dont need that expensive a phone.
i can live with the lag but not the "insufficient" space issue as it not only does not allow to install new apps, it also prevents updating of apps and even basic functions like email. always thought its like some bug or something.
Hi all who have the enhanced redmi 2, can I ask if I can use the same roms that were meant for the original redmi 2?
But I'm myself going to get it soon ! My phone is too slow.
移动的是自主研发的LTE TDD,全世界大概有十几个地区在用;
联通和电信用的是国际标准 LTE FDD,全世界大概100多个国家或地区在用。
LTE TDD理论最大速度100Mbps,LTE FDD理论最大速度150Mbps
As a frequent traveler to China for business trips, I bought a Redmi China mobile enhanced version. This China mobile edition is TDD-LTE based but also support FDD-LTE and WCDMA as what Singapore Telco use. It is only that when in China, the support of FDD-LTE and WCDMA is locked. However there is an option in the Sim menu to unlock it allowing the phone to become so call TDD-FDD LTE capable. Frankly TDD-LTE is much better coverage in China with a China mobile prepaid package.
When back in Singapore, I tested on all 3 telco sim and had no problem with LTE connection locally.
At RMB699 or Singapore $152, it is cheaper than the $179 price tag in Singapore and it support all network !
If you don't worry about warranty and have no concern installing google services on your own, I should say it is more value to buy the enhanced China mobile version.
