[Review] D-Link 890L
simic
[Review] D-Link 890L **Now with VLAN capable firmware
Executive summary: Big ass router, my wife was shocked by this black spider I brought home. :s13:
More impressions at: https://simicus.wordpress.com/2015/07/27/d-link-890l/
evq
I've been using this for like 3mth, so far so good. Just feel that the settings are very limited. Good for those who prefer easy setup & dont meddle with it after that. But not good for those who like to set every parameters to their preference.
I'm the 2nd type of user.
And yes, it is huge, I got a shock when I opened it up. hahaha
jonoquek
I belong to first type.. if everything work well.. I prefer not to twist it too much.. unless I want some unique features...
croc1977
actually the range is not fantastic ...
i still need a wireless repeater ....in a 4 room flat...
mine is red...
yes the router menu simple.......
shafina
I'm guessing the remote isn't included in the package? =D Haha...
Jokes aside, yeah the router looks pretty huge, I guess it compensates with its aesthetics, cos its one of the better looking routers I've seen to date, though I prefer the red version.
In terms of wi-fi coverage, I've read that its actually one of the better performing ones in the market, but I still prefer a wired connection for peer-to-peer purposes.
Good review bro, definitely a strong consideration.
AshSim
now the show price is $399 with the usb3.0 adapter. can anyone advise if its a good deal?
bear1sg
Can this device user as a Access point or AP?
any one can advice how to set it.
Ah-Pin-Kor
Give the AP a static IP address outside of the main router's dhcp range.
Disable the dhcp server under Settings >> Network
Then connect to the main router (LAN port to LAN port). Don't connect anything to the WAN port.
tungsten2
If you main router can do a IP reservation, then you do not need to do a static IP for your AP.
The DIR-868L have this IP reservation function.
