A sneak peek of Samsung's recently launched product! What is it?
In what situation will the new Samsung SSD T1 come in most handy for you?
  • Total voters
    43
xiaowhois
they really give out vacuum cleaner for buying ssd?? smaller capacity freebies are more appropriate.
Not surprise think perhaps Samsung learn from LG~ LG give out microwave oven for purchase certain of their products while Samsung give out vacuum cleaner for buy their IT products like Samsung Portable SSD T1
freebies practical good at least you dont need resell away and could use for own usage
xiaowhois
Don't forget guys, there's a new activity now. Details are in the first post and here's the gist of it:
If a picture really paints a thousand words, can you find the right words from these pictures to link you to the features of the New Samsung SSD T1? Take a hint from the weekly pictures that will be posted and guess what the features of the New Samsung SSD T1 are. Some are pretty apparent, while some might need you to get those brain juices working.
Keep tabs on the first post and watch this spot for more to updates to come!
Since HWZ post this picture again thus i write again differently (admin dont deduct points due to spam :) )
Racing car => Samsung Portable SSD T1 like ferrari racing car Fast and furious read and write speeds Up to 450MB/sec.
No Speed Limit sign => it refer to the the ssd write/read speed can match the usb 3.0 speed which Samsung Portable SSD T1 is using
Torque Magazine => we all know Torque Magazine is one of the magazine that SPH publish and the picture on the frontpage show a mini car which refer to the size of the Samsung Portable SSD T1 (2.8"(W) x 0.36"(H) x 2.09"(D) )
Gear Fit => it could refer as high tech product from Samsung like Samsung Portable SSD T1 and also can mean small lightweight of T1 which is weight less than 30gm
Blank notebook with pen => it could refer to Samsung Portable SSD T1 plenty of avaliable size to write 250GB,500Gb,1TB which which use 3D V-NAND stack up for more storage
HWZ could add in one Samsung digital door lock to represent AES 256 bit Encryption for Cutting Edge Data Security for Samsung T1 SSD
IlovePCW-ing
It's able to withstand TB of data written daily so don't think there's any issue bits essential an SSD ma. Same thing like the com. Just external.
from what i read online, seem like SSDs generally dont run hot, let alone warm
i think samsung include this feature more of a "just in case" situation.
i dont think transferring data a fast speed will cause it to heat up
xiaowhois
That is useful information.
Speed
Up to 48MB/s transfer speed with UHS-I interface * Actual speed may vary depending on use host device conditions and environment. * Write speed is slower than transfer speed
http://www.samsung.com/sg/consumer/memory-storage/memory-cards/micro-sd/MB-MP32DA/APC
I using Samsung Evo 64gb microsd on mine LG G4, the speed it provided more than enough for smartphones no issue dont need super high speed like Samsung Portable SSD T1 Up to 450MB/sec :)
xiaowhois
usually ssd wont run until become hot unless got malfunction or in Samsung Portable SSD T1 case maybe one component faulty cause heat issue
IlovePCW-ing
Quote for others to read.
Highest reward point is now 473 and five person redeem already.
Is the reward quantity official?
473 point is the max points without the bonus points.
those redeemed ones are the lower tiers EVO MicroSD cards i guess.
I think my chance at the Samsung Portable SSD T1 almost NIL :s22:
IlovePCW-ing
yes, possibly also due to external factor like environment
since its portable, if use under the hot sun surely it will heat up also.
speed will be throttle to try to minimise any more heat
xiaowhois
usually consumer IT products are design use indoor/office condition by default unless stated
WhiteHunter
if you use encryption and password protection you need install their software in order to access Samsung T1 SSD.
In office situation it is better to use non password protected as usually staff have no admin access to computer to install the software
it is not really hassle-free for mac
http://forums.hardwarezone.com.sg/95616392-post1701.html
isn't the software already pre-installed in the drive?
one of the cons of this ssd drive is the password. if the user forget or lose it then its quite troublesome to have to bring it to service centre. they should have something for us to unlock it ourselves.
noobiee
tbh, i have never heard of hdd or ssd failing due to heat lol
even if it does, i bet by the time the heat killed the drive, you would have moved on to other better capacity and much faster drives
IlovePCW-ing
A thought came to mind. What if we buy a external hard disk case and put the 850 pro in it. Will it be cheaper and the performance remain the same? Since essential it should be the same thing except the case design.
you probably can, except that Samsung 850 PRO is much bigger than the Samsung portable SSD T1
WhiteHunter
its been tested that this ssd t1 drive will heat up to 75 degrees celsius when reading files or higher if its with encryption.
Audiology93
Maybe if you put the Samsung 850 Pro in it, I think won't be as fast as the T1 Portable SSD? Unless you get a good enclosure. Or the size might not even fit.
WhiteHunter
some IT consumer products are designed to be used outdoors but yeah ssd drives are to be used indoors. if there is a rugged rubber case to protect it, it can be used outdoors.
Audiology93
i think by the time the warranty for the SSD already over :s13:
noobiee
samsung lol
you need to install the samsung software in order to use the password function on the T1 portable SSD
daring sia, put like this in the advert
noobiee
anyway don't you find the 256gb abit too little?
considering now hd movies also smelly smelly 5gb. lossless music 1 album also 300mb
how much can you store on the 250gb sia haha
lets not talk about the raw files by dslr
xiaowhois
dont hand itchy go set password lo unless u got top secret info inside or else later warranty end they charge u for reset password or even during warranty they can even charge u service fee since not their fault haha
NWT1978
same here but the fun / joy of collecting the points :s12::D
WhiteHunter
they can give out samsung gear s watch. we could also use for our own usage.
