[Maylyn's Review] ASUS RT-AC3200 Router
ykeen
Moderator
Moderator
I don't use vpn...
Any other vpn users can verify?
U can try test the L2TP profiles on http://www.vpngate.net/en
Just last week I was also testing my VPN on my ac66.. Also can't connect.. Was working previously (maybe a year ago) tried few VPN servers also not working.. I thought was problem on my side..
fishdundee
You are not alone....
ON my side, I have tested the settings by inputting direct into my android player, and also into my windows system. They are all working. But when I input into the Asus vpn client.... does not seem to connect.
Can Asus check and verify?
renfred89
then I no need test liao lor...
now asus can slowly find out whats wrong.. LOL :D
ASUS@SG
Suspended
Dear Fishdundee,
Just to confirm is "Client & not Server" right
i will test and let you know.
Best regard,
JK
ykeen
Moderator
Moderator
Dear Fishdundee,
Best regard,
JK
I have same issue on AC66, 3.0.0.4.376_3861.. yes Client pptp and l2tp inside Asuswrt GUI, trying to connect to a remote VPN server
ASUS@SG
Suspended
ykeen
Moderator
Moderator
ASUS@SG
Suspended
Yup, correct.. its client....
Dear fishdundee,
We have tried the RT-AC3200 with firmware 3.0.0.4.378.7838 and have no trouble to connect to a PPTP VPN server.
Would you please provide more detail information such as VPN server configuration or encryption type?
Best regard,
JK
glacieraze
Dear glacieraze,
Facing upward.
Best regard,
JK
All of them facing upwards? :)
Like this?
renfred89
Dear glacieraze,
Yes.
Something like this.
sacrificial-offering-oblation-joss-stick-candle-pray-god-jade-emperor-chinese-culture-traditional-religions-52044562.jpg
Best regard,
JK
Hahas this is funny JK!
Well, the 2 antennas at the side can consider pointing away at 45 degrees. The antenna will auto click into position..
The centre 2 sticks can point vertically upwards, while the lateral 2 antennas can also point at 45 degrees like the side antennas..
glacieraze
Originally I place it like that, but I think all vertical looks nicer :s13:
trenzterra
Hi there, thinking of upgrading to fibre and using ac3200.
As I'm on the ADSL mio bundle and recontract isn't up, I can only upgrade to the mio plans. May I know for the 1gbps mio home plan, does it also have the vlan tagging issue?
BTW. I don't use mio TV at all. We just subscribe because it gives us mobile discounts . so I was wondering if changing the vlan works on port 4 as per prior models? Do we need to do the change nvram thing or can just change via the user interface? Thanks!
