renfred89
- Nov 11, 2007
Hi there, thinking of upgrading to fibre and using ac3200.
As I'm on the ADSL mio bundle and recontract isn't up, I can only upgrade to the mio plans. May I know for the 1gbps mio home plan, does it also have the vlan tagging issue?
BTW. I don't use mio TV at all. We just subscribe because it gives us mobile discounts . so I was wondering if changing the vlan works on port 4 as per prior models? Do we need to do the change nvram thing or can just change via the user interface? Thanks!
thats right. the 1gbps home fibre is vlan tagged and you need to make the necessary IPTV profile on asus routers correct. Choose SINGTEL-OTHERS as your iptv profile and your set top box can be connected to port 4. there is no need to amend nvram through telnet or SSH.
