addicted-addiction
- May 31, 2010
any good deals for qualcomm quick chargers??
This one - CHOETECH Quick Charge 2.0 60W Multi USB. Can get between $28.90 to $38.90 inclusive of shipping depending on how many q points you have
http://list.qoo10.sg/g/431957131/Q100154577
Get NDP coupons, apply the $5 item coupon
http://www.qoo10.sg/sg50?jaehuid=Q100154577#50deals
http://list.qoo10.sg/gmkt.inc/Special/Special.aspx?sid=7380
if you have >1000 points, use all 1000 points to offset
Total cost $28.90, if paid via paylah, still can get 20% points as cashback bringing your total cost down to $23.12.
from the T&C of the event, "payment must be completed using DBS PayLah! to qualify", therefore i assumed that it will not be verified unless payment method is using PayLah.
Can buy most exp anker charger at this price ....
Quick charge feature that important?
That's what I'm thinking too.
Does this mean we can't use a mastercard item coupon to stack with the paylah cart coupon, since you can only use one mode of payment in the end?
Example:
$50 item
$5 item coupon applied
$10 paylah cart coupon applied
At the payment mode selection page, total amount for payment is S$35.
Depending on which payment mode you choose, one coupon will be invalidated eventually? Sibeh confusing![]()
do you have the paylah 50% cart coupon and also at least 100 qpoints?
if yes, it would be easy to see for yourself.
1. add to cart any non-discounted item maybe around $10 or more
2. go to your cart and apply the 50% coupon
3. click on "Place an Order"
4. scroll down and you will notice that only the PayLah option is enabled
5. above the "payment info", click at least 100 under "Use Q·point"
6. take a look again at the payment info, most of the payment methods would have been enabled
this method applies to mastercard coupons as well.
* however, for the apple watch / asus zenfone deal, qoo10 blocked the option to use qpoints, so using mastercard coupons will not be possible.
Speaking of bugs I've found quite a few over the years. One of the "best" bug i came across is the roulette a year plus ago
You know how you check in daily to spin the wheel,you get a ticket and spin. Well after spinning for that day, I was bored and decided to click on the roulette. To my surprise it spins. I was like I didn't buy anything and already spin for the day.
So I click again and it spins again. I was like puzzled and did it again. It only stopped after 20 clicks. So I did that everyday and went on for about 1 week. By that time I had lots of coupons,qpoints mameq,qstamps etc![]()
do you have q points? once you apply q points, it will "unlock" the mastercard coupon... go to a few threads before, there is a detailed guide on how to do it (if qoo10 has not fixed the bug)
@kandinsky try the method below
still valid now ? i can't do it myself as i have lots of qtickets atm.
Yup, have some q-points. It was after trying that guide that led me to my question.
It works in the sense that I'm allowed to select various payments method (nothing is grayed out). But my question is, will they cancel either coupon later after payment?
E.g., If I use mastercard, will they cancel the paylah cart coupon when they compare the records and saw that it wasn't paid with paylah? Or does it mean once payment is through, it's a done deal?
So, basically you can apply the following discounts for your item:
then paid by Frank VISA for another 6% cashback.
I cant seem to be able to use mastercard item coupon with paylah cart coupon keep getting popup messages over and over again![]()
