OnePlus 2 - NEVER SETTLE
ecneret_eel
Oops, paiseh, thought u have G4 riao. In that case get G4 lah. Gflex2 has same camera as G3 plus it has the infamous snapdragon 810 so really no point. Yah 801 is old but all the newer ones bar the 808 or exynos are problematic. And u don't really need that high performance unless u play a lot of 3D gaming. Also the super value price of zuk 1, u cannot go too far wrong one :p
Sent from Blackberry Q30 Passport using GAGT
well, the battery size is sick for the Z1, initially held back for G4 to wait for G4 Pro or G Pro 3.. lol, but along the way so many phones keep launching, my nose is bleeding.
Sent from LGE LG-D855 using GAGT
technolust
So is dual sim working? Some say yes, some say no. I am confused
Tiagong the China sets with hydrogen OS cannot use dual sim out of China. The ang mor review sites with the international version tested it and say it's ok in the US. So maybe those with international set need to advise. Also those with tiong set, try to flash to oxygen os instead and see if it works.
cwchee
ok just let me clarify!
I got a china set recently and it came with hydrogen OS.
Flashed it to Oxygen OS and put in two sim cards.
Like all current chipsets in the market, this is a 4G + 2G system.
It confirm works! Both sims can make/received calls but only one will allow for LTE connection at one time
Hope this helps
technolust
Hope this helps
Thanks, think it concurs with what the ang Mor websites with the international sets
djzilch
There are a lot of battery life reviews, mostly bad to average?
How are your screen on times?
Noirkw
Dual Sim
Sent from my Oneplus Two using GAGT
nothingz12
Hope this helps
As seen on the video below, 1:05-1:20 when sim 1 is on LTE and data, Sim 2 will have no option to choose any network. that's why you said it is 4G+2G?
Core2max
Any tips to get your queue up faster? I just signed last week... now my queue is 2 mio... I dont think I can get the invitation...
batboyz
Be active on OP forum. Reservation list is the last priority to be given invites.
Computeron
That is cheaper than its USD price if that'll be the selling price in SG.
Tats y i raised up that Q. and izzit int set?
NOW I KNOW Y GOT PPL COMPLAINING HEATY N BATT DRAINS FAST LE, techolust...
i think... think only ah... those heaty set is usualy from china ppl right, is becuz the use H... if use O os should be ok.
