Hwzers, be the judge yourself.
Quote:
Originally Posted by US Blues View Post
@mikiphile- I run Yggy with a speaker set-up, Yggy with speakers is certainly 3D in it's presentation of music. Iggy will fit quite nicely into the system you describe, Yggy goes away and leaves music, this is what we desire from a system.
http://www.head-fi.org/t/766347/schi...#post_11697570
Quote:
Originally Posted by llkmi View Post
Same here - I run Yggy on speakers only and detail and uncanny 3d image & realism are Yggy's strong points.(Although I am not sure I could identify any low points - but those elements are the ones that really stick with you.)
http://www.head-fi.org/t/766347/schi...#post_11698042
Quote:
Merv
I've auditioned Vega, Invicta, and Lampy 4, 5, and Big 5. Don't know how much more you need to know. Will keep it short. Vega is bright with robotic timbre and leanish bass; Invicta has body and tactility to hide SABREness, but is still slightly strident and gets quite congested in bass; Lampy has good tube implementation (good slam, clear, not distorted warm fuzzy ****), but this tube implementation shows poor DAC implementation - very digital with sibilance, stridency issues. Yggy is more resolving than any of those in terms of microdetail, and has best combination of slam/articulation.
Yggy is the most "3D" with depth and most precise imaging DAC that I have ever heard period. Some others are as good in terms of space (PWD2, Vega, M1, SFD-1) but not precision. This is via speakers using EC tube or Rag as amp. I have not heard TotalDAC. If TotalDAC has more depth, than awesome.
You may also want to check out HF. A few Yggy guys on HF have owned Vega, M7, PWD2, M1, M51, and all sorts of other DACs. You basically have to sort out the posts and see who is who, check their profiles, or just know the guys in question. Both Changstar and HF (DAC focused people) are kind of a smaller subset where a lot of info is communicated via PM.
http://www.changstar.com/index.php/t....html#msg68503
