Path of Exile thread, the revival
TrueBeliever_jh
I die also don't want to use lioneye's, I using a rare shield with 1.7k armour.
it got HP and some block chance. the only thing i hate is the lack of resist...
ended up i have to use the rest of my gear to compensate this problem..
but so far i think my gear is okay. probably jus need a new amulet.. with a properly rolled crit chance..
Vulpix
Moderator
Moderator
Remember, weapon more important than anything you have on you. :s13:
TrueBeliever_jh
https://www.reddit.com/r/pathofexile/comments/3ibhyg/thanks_metacrafting/
it was 1 ex B/O , and the crafting costs were 2 ex for the meta mods - so 5 ex total [and some chaos and alchs to craft the actuall mods] I bought it, put on the "prefixes cannot be changed" mod from haku, and scour orbed it - to only leave the 2 pretty high physical rolls, after that i crafted the multimod from elreon on and put the 3 master mods on it
so Scouring will remove only the suffixes after the "Prefixes cannot be changed" meta mod is applied? wah really can recover screwed up wpns~:s13:
Vulpix
Moderator
Moderator
I got bad news for you. That ahdoi managed to craft a Tyrannical ambusher under 100 alts. :s13:
DLMTE.
You just concentrate on leveling, getting to maps and gearing first lah. :s13:
moi got to act3 eternal library there liao just did a 68 map white de... ded to the unique boss so sad LOL need better gearrr
FappingKing
High Honorary Member
which map? remember the boss name?
ur lvl now just go clear act 3. then go act 4 clear the mines quest for the 1 free passive point then start to farm dried lake.
DLMTE.
hmmm hokayy :D tropical map cant rmb name of boss :O
retarded
Heng almost rip yesterday fighting dominus on tempest merciless, his 2nd form really hurts even with max resists and granite flasks.
DLMTE.
If my paper caster can tank 2-3 hits from the boss, I am quite sure his gear is the problem. :(
Can tank quite a few hits but flask regen can't keep up with his dmg need make use of decoy to whack lol
Vulpix
Moderator
Moderator
You what level now? If you are below 70, just go to Dried Lake and farm up there. Bigger packs, more stuff to kill, and got Voll over there which is pretty much a loot bomb.
DLMTE.
Lvl70 now I think haven't clear act3 lol tmr night onwards can chiong lvls liao yay
