R9 290x vs R9 390
djdestiny
390 is effectively almost the same as a 290 apart from clockspeed bumps. Same goes for 390x and 290x
Only more VRAM, which is only useful if you're going multi-card/multi-monitor/4k.
Not that you'd want to do that ... on more than 1 Hawaii now. It is as hot as hawaii's weather is :s22:
The Fury X is a exception because it's memory bus is so fast that they don't need 8GB for 4K.
I'm sure there are 290xs floating around for low amount of monetary outlay. The refs are very cheap but you do need to watercool them.
SEvsNK
Recommend to get the sapphire Tri X version if possible, keeps the volcano reasonably cooled
trento
was hunting for a 290/x at sls last week. cannot find. Mynextcom sells but pricing quite close to the new series so might as well get new one.
