renfred89
- Nov 11, 2007
Hi guys. Is the 5Ghz-1 is supposed to be slower than 5Ghz-2 ?
Tested using iPhone 6+ on M1 fibre 1Ghz home broadband.
no, both 5Ghz are supposed to be running at the same speed based on the same radio specs..
in ac3200, one 5Ghz may be handling the slower speed while another is handling the higher speed when you have obviously many devices connected to it. otherwise, there is no difference to the radio for 1 and 2, although one is running at the lower 5Ghz channels while another is the higher channels.
