Best petrol brand
evilviser
Hello all! What you guys think is/are the best petrol brand/s? Personally for me is caltex techron 95 on my civic 1.8. Have been wanting to try the new esso fuels.
Fatfool
In Singapore, all the pumps and tanks are relatively new so it's unlikely to have water in the fuel you pump. Hence the cheapest that your vehicle can take is the best lor.
Petrol is mostly iso-octane anyway. So long as the ratio of it is sufficient to prevent premature combustion then okay liao.
warr
petrol is chemical. it doesn't have a brand. ;)
keenklee
Caltex Techron ron95 for it's cleaning power
Esso 5000 for slightly more power (compared with Caltex)
any RON98 for even more power
Fatfool
You realise you need a really high compression ratio for the RON 98 fuels to have any effect right? Most mainstream turbocharged vehicles only require RON 95 fuel.
keenklee
It works on my previous low compression engine
- when fully loaded, the ability to accelerate up the same slope.
seowbin
SPC for cheapest petrol, somehow i feel caltex is weaker compare to SPC
everytime i switch back to SPC from caltex, i feel the car more wild
shell, no special feel except weee power. Before turbo kick in, the torque it produce really solid
esso seems to really clean the engine well or at least give me the best mileage after i try out their latest "petrol"
review based on 98, using European tune which requires ron 98 :s34: but i still cheapo go malaysia for vpower racing at times :s13:
runeruin
why do you want to keep promoting use of 95?
its true most engine don't do high compression and 95 is sufficient
but the same normal engine reacts differently for 95 and 98
from my limited knowledge,valve timing changes accordingly to more efficiently burn the type of RON fuel
the faster reaction time upon accelerating is what most driver want rather than the flawed higher ron=more power logic
evilviser
On my 1.8 civic, I've tried caltex 95 and esso 5000. Feels that my car is smoother and quieter when on caltex, rougher when on esso. Have yet to try shell and spc. Heard shell "burns" fast.
Fatfool
So you tried both RON 95 and 98 fuel in the same vehicle.
Other than the test not being objective (since you apparently know which fuel you are using at any point of time) nor measured with a dyno, you also realise that you didn't drain the petrol out between tests right? If you have half a tank of RON 95 fuel and then top up with RON 98 fuel then how? :s13:
So what happens when you use a say... RON 100 fuel with a higher RON number because they added ethanol? How? Also more 'ability' to accelerate up the same slope? What is 'ability' anyway? Torque? Acceleration? Power output?
Fatfool
Because it's silly to pay more for something that gives you absolutely no benefit at all; not even bragging rights.
With my more than limited knowledge, most 'normal' older engines are unable to modify their ignition timings. That is the method used to compensate for filling up with a lower RON fuel that is easier to combust at a lower pressure. Funnily enough, this affects the power output and not the 'reaction time'. Why? Cos higher pressure (of the fuel-air mixture) decreases the entropy. That means that with lower than optimal RON fuel, the mixture is ignited beyond the point the piston fully travels up. Something like the position figure 3 is in below
Lower entropy means you can extract more work from a system.
Modern vehicles may have sensors to modify the ignition timing though but you can't get a compression ratio higher than the maximum when the piston is all the way up. I know some Holdens are able to do it as does the Prius.
Now, how do I understand this sh!t? I'm a Chemical Engineer for goodness sakes. I drive a turbocharged vehicle and I flip open the manual, see RON 95 and that's what I pump. Cheapest optimal fuel.
I'm telling everyone else to do the same. Some engineer was involved in the design of the engine and that person knew what the optimal point was.
The only reason why you might need higher RON fuel than what the manual says is if you did some serious modding and/or remapped the timings. But at that point, you'd have access to a dyno and would know what you are doing.
So as I'll say it again. Look at your manual and use the described fuel in there.
todayisgood
Lets come back to ts topic "BRAND".
Assuming RON 95, which brand gives the best mileage, cleaning, etc... I guess this is the discussion.
NoLogicLah
but it is proven fact that over few months of 95 usage and 98 usage. on average 95 gives me 1km less mileage per L of petrol.
In the past due to price difference it is better to for 98. Now the price diff is 30cent/L. so bo hua liao.
pump 98 for 3 years till recently then change to 95
