[Review] TP-Link Archer C2600
evq
[Review] TP-Link Archer C2600 MU-MIMO
Hi all,
I will be doing a simple review on this product. Got it last week at $279.
Product Link
Believe the key selling feature is the Multi-user MIMO (MU-MIMO)
evq
Physical
Right Side
1) 2x USB3.0 ports where u can connect either a HDD or printer to them.
I tried a USB thumbdrive, and is able to share files & playback a full HD movie without any problem. Did not try a printer.
2) The rest are self-explanatory.... wifi On/Off, WPS & Reset
Back
4x LAN ports, Internet port, Power port & Power On/Off
evq
Setup
Step 1
Set up as shown
Step 2
Open an Internet Browser, and enter http://tplinkwifi.net or http://192.168.0.1, this will bring you into the Setup page of the router
Step 3
Enter the default admin for both username & password
Step 4
Once in, the wizard will prompt you to setup a new username & password.
Follow the rest of the steps.
Initial setup was easy. Took me about 5min to 10min.
evq
Wifi Speed Test
Pls note that this is a relatively new router, the firmware version is 1.0.0 Build 20150610 Rel. 32140, thus the speed may still not hit the full potential yet.
Transferring of 1.5GB mkv file from NAS wired to C2600 wireless to laptop (Killer N1202 adaptor)
5Ghz at 5m
2.4Ghz at 5m
Multiple Device Test
I connected 3 devices and playback full HD movies from my NAS at once at a distance of 5m;
Note 4 = Playback a 4.5GB mkv file
Note 10.1 (2014) = Playback a 10.3GB mkv file
Laptop MSI GS70 = Playback a 7.8GB mkv file
I tested for 10min, all of the playback are smooth.
evq
TP-Link Tether App
This app (avail in both Android & Apple)provides some basic overview of the network & settings for the C2600.
Network Map. It shows my NAS, laptop, DLink powerplug & my Note 4 & Note 10.1
Some basic & yet useful settings
By entering http://tplinkwifi.net or http://192.168.0.1 in your web browser, you can access the C2600 router settings. I like the fresh & clean look of the Configuration Page.
Basic Tap
Advance Tap
evq
Signal Strength
*All router settings are default.
I took 5 readings at diff rooms (blue dots are the exact location I took those readings). The bars show both 2.4 & 5Ghz.
Average readings are taken after monitoring for about 3min.
My 5Ghz readings seem to be a little bit stronger than the 2.4Ghz.
Do note, if the signal is at the Pink level, it is very weak, almost 'non-existence'.
evq
Final Verdict
Setup this router up last Sunday, since then, did not experience any dropouts or unstable signal. Runs cool, just slight warm on the surface when I place my hand on the top of the unit. Love the configuration page, light blue & white theme makes it easy on my eyes. Layout of the pages are clean & neat, easy to understand & find my ways around.
The Tether App is for simple settings. A good to have feature, comes in handy when u need to disable the wifi, change SSID, password etc., instead of powering up my pc to access those settings.
Signal strength is rather similar to my Dlink 890L & slightly better than Asus N66. As this router was just released with the firmware version still at 1.0.0, believe there are still plenty of potential.
PROS
1. Easy setup, took me max 10min.
2. MU-MIMO (Multi Users-Multi In Multi Out).
3. Beamforming.
4. Dual USB3.0 ports.
5. Relatively slim and small.
6. Detachable antennas.
CONS
*Seriously, I still can't find anything to fault it as for now. Will update again if there's any after further playing around with it.
evq
This is such a pictorial review.. *thumbs up*
Thanks.
I think no point write too much. No one will want to read. Unless it is some important points to note. And Pictures tell a thousand words.
evq
Great work! Waiting for your readings and conclusion. Thanks!
Thanks.
Anything u need me to test for u?
Can't help u on the speedtest as I don't have the latest ac adaptor. The best i have is my Note 4 which believe u have seen my test results. My laptop got lousier results.
trueimage
Thanks.
Can check for me if it is possible to set "AC only" for the 5ghz band? Also, is there any support for vpn client and download manager like in the Asus routers? Other than speedtests, i guess i would like to know if you have experienced any dropouts when leaving the router on for a few days
I still cant decide bet this and the Asus ac68u - prob need to wait for more reviews. TPLink is a good brand - i have used their 1043 and 4300 routers before and they worked flawlessly. In fact, google has chosen tplink to be their partner in producing the first google router - the Onhub
evq
Yes, there is AC only option
Got VPN Pass-Through (PPTP, L2TP, IPSec) according to the spec. No idea how vpn works.
Since last Sunday, not a single dropout.
trueimage
Thks, evq.
A couple more Qs:
- when setting dhcp reservations, can u use yr own names
- what r the bandwidth settings options esp for 5ghz
- is there option to turn mu-mimo on/off
- can this router act as media bridge
- can it act as wireless extender
Thks
trichard
I just bought this router ... Off WiFi...and no antenna attached... Just to act as a high speed router with Lan connection..
This is the first router with dual core 1.4
renfred89
Wah uncle Richard, you so hard core.. buy already but use as router only.. hahas
trichard
Ya my main WIFI unit is stil my fav AC3200 ASUS conected up as AP in sitting room.
The Fiber point is in Bed room and i do not want any wifi ... but need a high speed router .. saw this 2 core 1.4Ghz even faster than Asus AC3200.... so i dump the ******** Dlink DIR868L 1Ghz Dual core ... hence hoot ...
Now 4 phone WIFI youtuble at the same time ...also no lag liao....
Using the ******** DIR868L lag and wait ..
trichard
My usage......
