Ask a Bicycle Question - Part 5
Gixxerfied
Been awhile since i cycle(Due to the haze), cant wait to get back to cycling..Meanwhile, upgrading some components..
Try to jog in the morning when the haze reading isnt so bad..
Sadisticnoob
hoots from bike24 (the rest are other people stuff)
azz909
Been reading about wide rim wheels and tires being faster than the normal ones. I like the idea that it can more forgiving on uneven surfaces but for cornering I think our roads are mostly straight with almost no challenging turns, even 23mm tires will have no problem.
I am more interested in the comfort but how true is it when comes to speed.Expert opinions? Asking coz thinking of getting new wheels. Stick to deep rim or wide rim?
L'oreal Paris
Hi guys was wondering
Between 25 and 28c
Which one would you take
What are the pro and cons for each size
Usually where will you guys buy the tyres ?
Cryogenist
Between 25 and 28c
Can your bike fit in 28c? Unless is endurance road bike, CX or Gravel, standard road bike can at most put 23c for older bikes, 25c for recent models?
28c almost impossible to get locally if it's race tires.
I just ordered 28c GP4000s from Bike24.
L'oreal Paris
I am using a 28c right now but spoil already my bike model is
Is there any such thing as 25 front wheels 28 back or vice
Versa?
Fuji absolut dx is my bike model
any ways to know if the bicycle can further upgrade
Cryogenist
Versa?
This bike quite old already right?
Depending on what you want to upgrade, it may not be very cost effective.
Edit: Yes, there are people who put different tire width for front and back.
L'oreal Paris
think so its stated 2007 i buy it 2nd hand
can don't mind explaining to me different tire width advantages and disadvantages ? srry i am new to cycling :(
Cryogenist
Although not comprehensive, some advantages are increasing comfort and traction for wider rear tire, slightly easier and lighter front steering for narrower front.
Disadvantages are that you have to keep two different type of spare tubes if one of them is 28c and wider. You cannot do tire rotation for wear as well.
