Recommend a Good and Cheap Air-Con Service Company
RayOfLight
aircon air flow is quite good but not cold..
chemical overhaul done about a year ago and I had those chemical spray from home fix done recently.. air filter washed.. sometimes in the morning or noon is some how colder.. seems like only affect 1 out of the 3 units.. what could be the cause? any cheap and reliable servicing coy to diagnose such stuff? only available after office hour or weekend..
herzog21
I seem to have the same problem. Servicing was done last Fri. Refrigerant was pumped in and the usual cleaning of aircons was done but some how all 3 aircons was not cold enough at the preset temperature. Some nights it would be cold but other night it would be warm/cool only.
testerjp
Can i ask, when you guys do servicing.
The guy got vacuum the fin and tray at the back and take out the big roller inside to wash?
Or just vacuum the front fin, filter pipe and trays only?
I think use this to benchmark better.
If they only vacuum the fronts, then it's very little work.
Say until how good also no pt
RayOfLight
did you ask them to check for you again? seems like all the recommended contractors are all busy for now, any other contractors that are available immediately?
kimsim
Suspended
Maybe next time you guys can engage Ah Yi serving
Ah Yi recommended link
He should do the different. :D
Hi, what are your aircon brands and model? Inverter or non-inverter?
Yes, we'll vacuum the fin and remove tray for washing during normal services. For the roller, it depends on the aircon brand/model. Some can be removed but some can't. We'll remove for washing if it's removable ;)
kimsim
Suspended
Their website says SMS or Whatsapp is preferred as they will respond faster. Well, this morning I whatsapp them till now no reply. Guess biz too good. I will skip.
Ya he should too busy, I guess too
zensushi
Moderator
Moderator
Air Connection
Just signed up for a quarterly aircon maintenance package with Air Connection.
Have been using them for ad hoc servicing for a year now.
Service is good & the best bit is the quick responses to WhatsApp texts.
YMMV, of course... :s8:
kenapa siol
Just had chemical wash on my MBR unit last week on my 4rm flat. Notice that the other 2 br, it takes quite a while (45-60mins) then the room starts to feel cold (23-24deg). While the MBR unit gets "colder" in the middle of the night. It wasnt like this before the AC guy came. Not blaming anyone here, just want to check with AC expert here what can i do myself to check if its normal before i ask the service guy down to check it out.
Could it be gas leaked? Remote control not functioning properly? Recent haze causing the room to be extremely humid hence getting to the temp i set takes longer?
STREAM2
Hi KS,
What fan speed you used ?
For troubleshoot, click on the "Useful Articles" on the right side of this website:
http://www.astiquer.com/index.html
Raymond_Hu
Anybody have good recommendation for repairing my Toshiba inverter FCU where it cannot receive signal from remote control frequently?
chrisslam
Hi, anybody able to advise on system 5 aircon for HDB EM (built 1989, 26years)?
Currently using system 3 for 3br. We're looking to install aircon at 1 br + living hall as too hazy & humid to close window without aircon but unable due to HDB old electrical capacity. Anyone has same problem with hot air flowing inside house due to compressor?
chiaki11
Aircon Cover and Remote control
Hi,
Anyone know if we can replace the aircon cover, ie the casing which has the vent there.
The unit is still functioning well but the vent is spoilt and hence i cannot control the direction of the air flow, etc. And also my remote control sensor is probably spoilt as it cannot detect my remote control.
Or is there such service at all?
Any recommendation/suggestion is welcome.
kimsim
Suspended
Hi,
What is the brand/model?
MorningOwl
Called Ah Yi and ask him to help me service my aircon. Did a cleaning servicing, vacuum the pipe as got leakage and refill of gas. But after around 5 days. Aircon not cold again. Service was done during June. Call him and SMS him till now no reply me.
MorningOwl
And so what's wrong with my aircon? Compressor spoil? When I on the aircon the compressor not moving or vibrate at all.
