iPhone 6s/6s+ Accessories Discussion (Cases/Screen Protectors etc.)
Frosty Wind!
Singtel one is mono duraglass selling at $29.90 fully covered
Challenger one is vouni but its not fully covered at $9.90.
Thickness wise i am unsure, sorry about that :)
So far used both can feel 3D
totally covered like the hot bending or is it like the edge to edge?
karenwoods
Any review on power support air jacket from Apple Store? Thanks
I bought a power support air jacket for my iPhone 6s plus from Epicenter. The packaging said for 6/6s plus.
The case is very very tight. You can squeeze the phone in but taking it out is a big pain and takes a lot of careful effort. I was so worried that it would scratch the bezel of my phone. I think it is more for the 6 plus.
I ended up getting the Spigen thin fit to replace the PS. It offers min protection but is similar to the PS air jacket.
DQUEK123
Power Support, I don't trust the sticker pasted on the package that says iPhone 6s+/6....
This is totally BS.
kira1984
What TG are recommended to use with the Spigen Ultra hybrid ex case? My TG tends to lift up whenever I put the case on. Any kind soul can help? Thanks
ragnarok95
Senior Moderator
Senior Moderator
This is totally BS.
i bought, cracked after 2nd snap in. its meant for 6 plus. Im still pending reply from PS.
Look at this: http://www.gsmarena.com/compare.php3?idPhone1=6378&idPhone2=7242
It's a 0.1/0.2mm diff. That is already a very big diff. It mean 6S is at least 0.1/0.2 thicker/longer/wider.
It is NOT wise to purchase a PSAJ for 6 and use it on a 6S. Yes, it will fit, but it will be super tight fit.
Deathgod
i searched thru the threads but do not seem to find the post about spigen slim armour with deiva full screen TG protector. are they compatible with each other the spigen case will not break the TG edges?
athenodorus
is it really that strong
i dunno about how strong cos i never purposely go drop it.:o
i like the rhinoshield because it protects the phone from drops and i like that i can feel and see the naked phone. since it doesn't cover the back, the phone also gets cooler this way (dissipate heat better).
most of all, it doesn't add much thickness and provides better grip.
now i'm waiting for k11 bumper to replace rhinoshield.
Swordtail
Anyone using Doc Artisan Sport Wallet Case or any idea if available locally?
http://www.dockartisan.com/collections/iphone-6-plus/products/artisan-leather-wallet-case
