The Samsung Galaxy Note 5 Thread
Bongstar
Hi guys, when u charge your phone..does your adaptor and phone feel very hot? Also i would need to restart my phone to have it rapid charge. Anybody also having same issue?
tikokia
Finally bought Note5 in Silver Titanium.
Your note 5 duo sim is export set right? which country set is it?
does it have VOLTE?
renfred89
Adapter feels hot. Phone feels warm. And fast charging shouldn't work only when it is off..
renfred89
have been using note 5 for a few weeks, a problem confused me quite a lot.
If I received a app notification, for example, a message from wechat, what I find is, if I don't read that message, it will keep on reminding me. I set my phone to vibrate, so it will vibrate once every maybe a few minutes until I open wechat and read the message.
Is there a way to just reminder once after message is received?
Not sure if there is anything wrong with my setting.
I think this is the settings for wechat.. I am not aware of any other settings apart from the built-in messages.app
keith
Should not clear the RAM......Android will always cache apps that it thinks you are going to constantly use. Clearing RAM will definitely waste battery as Android will recahce. Anyway with 4gb of RAM, why do you need to clear RAM?
i have not used such a 'feature" in my past devices, and this time round, since N5 is "almost" so perfect... so i tot why not see if SS could have enhanced this "feature" too. Honest, free RAM is more, but so has batt usage increased too.
A typ 6am ~ 10pm day would end with 40+ % remaining batt, but with that "feature" it dropped to 20~ % only.
*faints*
CatLuVer
now i think no one care abt simi non removable batt or no microsd card... now ish many ppl concerns/care about... SLEEPING issue... :s13::s13::s13:
Yes... :s13:. Many ppl are awaiting for updates to fix that issue lol
renfred89
Idk If it's the icon causing my battery draining lol
VoLTE don't cause a drain in battery life. This is something not new actually, and it has been around for a year or two..
If you insist it to be removed, you need to inform your telco and they will make sure they disable the feature for you..
