Fibre Internet Experts Please Come in Advise
djbecks
Suspended
Hi Guys
I have a big headache now with my Fibre Internet for my new BTO 3rm flat, hope you guys can help and advise.
My Current Singtel fibre Plan is a 200mbps.... I may not be able to upgrade the speed because they will force me to sign up for channel packs which I have never used my mio for the past 2 yrs, I went on with this plan because of the 30% discount I get from my 5 singtel hp lines.
so, should I sign up for another fibre plan? m1? my republic? those 1gpbs @ $39/month plan? if yes, use what router?
many thanks in advance
1. open net box is located at main door shoe cabinet
2. I need Internet access for 3 locations
Living Room - Android Box (Wifi or LAN?)
My Room - CPU (direct LAN connection) + Android Box (Wifi or LAN?)
Master Room - Android Box (Wifi or LAN?)
I confirm need to pull 1 LAN cable from the modem in the show cabinet to my CPU, as for the Android boxes, will the Wifi bandwidth suffice?
how should I setup my fibre internet for my new home? how many LAN cables should I be pulling from the shoe cabinet?
renfred89
Hi Guys
the first part of your question deals with which plan should you choose right? you are in the exact situation as me. giving up the FEB will give up the multi-line discount while continuing the FEB+, its much more costly..
well, i guess you need to do your sums carefully. for me, if i take up the FEB+, it will be much more expensive for me even if i factor in the discounts.. so i guess if its expensive for you, you might wanna try the singtel unlimited fibre service at $50/mth. it comes with a 10% off mobile line for the key line holder.
the second part of your question is about the structure cabling, i think i suggest you pull 3 cables to your 3 locations. android tv might work better with cable than wifi.
my current set up is that i have lan points in all rooms for the benefit of reliable lan service. if i need wifi, one of the points can be connected to an access point, in which it also expand your LAN ports..
sadboy
Hi Guys
Are you planning to relocate your old Singtel 200mbps plan to your new flat? If you are not relocating I think you can sign up M1 Fiber.
Based on what i been reading usual the router will be inside the main door shoe cabinet which you should get weak wifi signal in master bedroom (and the bedroom beside MBR).
Since is a new BTO, you can reach out to some network company to assist you convert telephone point to network point. I done that last year spend about $130 convert 4 telephone to Network point.
I get myself a cheap small xiaomi router to place in one of the empty room to boost to network coverage at the far end of the flat. Do expect short wifi disconnection when your laptop/phone switch between router (Router 1 to Router 2). This should get you good wifi speed Master Room and living room.
Living Room - Android Box – LAN point. Believe HDB provide one LAN point from shoe cabinet to living room.
My Room - CPU (direct LAN connection) – Convert the telephone point to LAN point. So you can hook up CPU direct LAN to router @ shoe cabinet
Master Room - Android Box (Wifi or LAN?) Both also can but wifi will would another router because wifi signal from shoe cabinet would be damn weak for video steaming.
djbecks
Suspended
thanks guys,
@renfred89 bro I have been on FEB ever since fibre came out lol and now stinktel do this stupid move to force regular consumers like us to pay extra money for content we don't use..... my 5 hp lines enjoy up to 30% discount so I really save up a lot on mobile lines + I always upgrade my main keyline every 1year so that's another extra $350 I save, thanks for your suggestion, I also had a feeling I wont be able to rely on the wifi as the signal will be weak and the 200mbps cant do much
@sadboy, that's damn cool of you to give the advise together with pictures, I didn't know telephone phone could be converted to data points, would you happen to still have the contact of the electrician guy? I have to relocate the 200mbps, but don't know if the speed can tahan 3-4 data points, if shared out evenly it means each point only using 50mbps....
if you live near rivervale crescent do let me buy you coffee man.
sadboy
thanks guys,
The 200mbps plan is more then enough for most household.
Your Android box, Phone wouldn't be able to draw that much internet bandwidth anyway.
Unless everybody is at home steaming HD video, download files and Gaming that may affect the speed.
Private Messages sent to you. :)
