Xiaomi Box Android TV Box
Solidus_GZ
anyone nt able to play sound from their avi on their mibox? appreciate if anyone know a way to resolve this.
icearmour
in mi box mini have less than 1gb most of the time. how clear up to make space...esp system apps specific for china users....
clock_ED
Where you all purchase the new xiaomi box ah? Can PM links (if not convenient to share here)?
Thanks. :)
gregory_choo
thanks!
can PM link to seller for taobao via 65 (never use taobao before).
Lazada from which seller ?
paste this link at 65dg site, total including service fee and surface shipping should be less than $80.
http://world.tmall.com/item/4178773...714.0.0.Xa29vA&sku_properties=5919063:6536025
lazada from here, try to get 10-15% discount during weekend.
$80 after 15% discount. If you have ntuc link card, use "NLTZUDC" for 20% discount.
http://www.lazada.sg/xiaomi-mi-box-3-quad-core-android-44-smart-tv-4k-hd-box-export-1808959.html
or
http://www.lazada.sg/xiaomi-mi-box-3-quad-core-android-44-smart-tv-4k-hd-box-export-116651.html
clock_ED
or
Hi gregory_choo,
I see, ok thanks man. :)
dreamercyc
Hi Gregory_Choo,
My mi box cannot read my mirco sd card. It is a 16G sandisk class 10 card. Can you or any kind soul help me pls. Can I check when I insert the card the chip is facing upward or downward? The card is in FAT32 format.
Thank you very much!
redname
Hi Gregory_Choo,
did u push all the way in?
mine was like tht cause the spring behind was faulty and the card didnt go in properly
redname
anyone paired their mibox with a bluetooth mouse?
saw someone pair with logitech bluetooth mouse but too expensive for me, wanna buy cheap one
dreamercyc
Really? must put all the way in? will it spolit the card? After pushing all the way in does it solve your problem?
Thanks
redname
Thanks
mine is working but do note i'm just assuming ur's is same problem with mine hor
