The Samsung Galaxy Note 5 Thread
tikokia
i used to get the sleeping issue every morning after leaving my phone to charge overnight
after the update no more lagg, hang or sleep, feels so much more responsive and smoother now, open whats app also no more lagg
Garfi3ld
Same here.. I don't get the sleeping issue often but so far the feeling is smoother.. will monitor further..
nuscape
Anyone else here using the dual sim model from Taiwan SM-N9208? How do you overcome the caller id issue? Can share please? I'm getting really annoyed now coz of this issue.
Sent from Samsung SM-N9208 using GAGT
Bapenigo
After doing factory reset and the problem still persist. Super annoying. I don't get the option to clear my default browser.
By the way, i am using nova launcher.
You should reset your phone then.
Sent from Samsung SM-N920I using GAGT
ruffruff
didnt realize that under settings - data, i can turn off background data for apps. this is so much better that we can turn off background data for apps that dun need it.
Whizdom
Guys , I intending to get note 5 next month probably recontracting it.
I've lots of whatsapp text/pictures everything.
Is it possible to transfer all my whatsapp text/pictures from NOTE3 to NOTE 5?
Thanks
shager
Thanks
Yes you can do a perfect transfer. Back up the what's app from the app then copy the folder to the note 5.
Whizdom
i intending to sell away my note 3 first then top up abit when i recontract so that means i need to backup my whatsapp folder to main laptop then when note 5 come i just transfer it to my note 5?
cos the text/pictures meant so much to me and can't afford to delete away just like that
lxb_70
yes, can copy into comp... whatsapp folder in your note 3, copy the WHOLE thing into your comp, after that u transfer into the note 5 (also using comp to connect) then, install/activate whatsapp... imo
Whizdom
thankyou so much :) :D
