[Official] Apple iPhone 6S/6S Plus Discussions
kopi22
Guys, whenever im done using my phone, i will kill app.
This also make whatsapp and other apps NOT TO NOTIFY me when theres incoming messages.
Is there a way i can make it notify me?
Perhaps you can start by practicing not to kill apps. I was an android user as well and still switching between note 4 and iPhone sometimes. So killing apps is like a habit when on android. But seems like ios is better in handling background apps. It doesn't lag or crippled the user experiences even I don't kill apps.
Sent from inside the toilet bowl taking upskirts using GAGT
manofsorrows
I just realised Malaysia iphones do not offer any more applecare/applecare+. In terms of support i think they are better off buying it from sg ?! :s11:
sabanuah
I use the healing tool. But you have to be patient with learning it. Sometimes I will use Photoshop on my Mac before sending it to my phone instead.
I tried healing. It actually sort of erase or distort the face. I had a brief session with my colleagues G4 and the phone auto beautify the face without having to do anything
dawntime
Is this a new feature? Since when does notifications stop showing even when killed off multitasking menu?
Conan1986
I'm torn between the 6s and 6s+
Avid Samsung user/promoter previously.
I'm pretty much using Samsung Note all my life from Note 1 to Note 3.
Recontracting tomorrow and comtemplating the 6s w not as good battery and camera or continue with the larger phone.
Any iPhone 6s user able to advice?
Thankyou!
Go for the 6s Plus since you're already used to having big phones. The battery life would amaze you.
No, in my experience, sometimes notifications would come slower when it's killed.
dawntime
Generally yes because the app does auto refresh when it is launched and kept in the background every now and then. Also with the fact that push notifications aren't always prompt (technical reason).
But his statement clearly was NOT TO NOTIFY, which is entirely wrong in nature.
auzzuro
hi recently i decided to get a bnib iphone 6 from carousel .. the seller told me it was a bnib set and pass me the imei no to check .. i call up apple and ask about it and was told the set warrenty has been expired but when i log in to their website n key in the imei no it show the set had not been activated yet . may i koe why is it so ? anyone kind soul can ans this ? the guy told me it was a singtel set ..
sabanuah
Bro thanks for your reply. Since you are so eager to correct me, +1 point for you.
chester121
Think you should try calling Apple again to check again. Also inform them that when you used their online checking tool, it showed that the set had not been activated yet. Clearly one side is erroneous.
Anyway, if the seller is genuine and it is a Singtel set, he must've gotten it on their online shop cos that's the only way it'll be delivered to him sealed.
dawntime
And also with regards to your question, you have the ability to keep the app running open and running in the background for some improvements, no guarantee as some notifications may still not get beamed to your phone. Bring the app to foreground every now and then would be the best to stay connected to any notifications.
Conan1986
I believe the website info should be more accurate and the Apple Representative so that the warranty is invalid so they took it as expired.. May be wrong but... How is the Singtel set BNIB? Unless he got it via delivery, it would have been automatically activated if he got it in store. Check this out with the seller.
