Xperia Z5 Premium - World's first 4K display smartphone
rssd21
Turn off adaptive brightness. It will be better
The adaptive brightness works better under the sunlight.
The screen is actually bright enough to use under direct sunlight, unlike my S5 which is good for all conditions except direct sunlight.
Takodoro
My experience with Z1 is a lot better though....I had turned off adaptive brightness and am going to monitor it for the next few days....
viperx
I agree z5p is not as bright. I still have adaptive brightness turned on but my brightness is now set at a quarter of the slider bar. My old z used to be at zero level all the time..
rssd21
As an ex-owner of Z1, it's screen may be slightly brighter but IMO the Z5P screen looks better.
ralph79
Anyone had image enhancement enabled?
I had this enabled and after some usage, it automatically disables itself.
Quite annoying to have a feature that doesn't work.
saiyan2005
Compared to my z1. The screen is much much better. Plus the z1 screen look very yellowish compared to z5p
carlover76
My Image enhancement is always set at X-Reality.
carlover76
Looks cool. Is this available in local shops or online only?
I just saw someone using this IMAK transparent case when I am with Jimmy, the case is even more yellowish than the one which come free with my phone from Hong Kong.
I will be changing to the transparent case from Jimmy as it is much tighter and thicker than my current case.
