battery saving tips
jazzman80
xperia users, just add in any tip so that we can have the most efficient ways to save battery.
do share any app that processes power and mobile data in the background too!
jazzman80
standalone Facebook app
my own solution,
surf Facebook on browser ,
browser to use, UC mini ,fast and efficient.much lower RAM usage than Facebook app.
cons:
no prompt notifications
slower loading than chrome
can't zoom in via speed mode.
upload of photos need many clicks via speed mode.
pros:
saves alot on battery.
night mode to reduce eye strain.
no ads.
swipe your thumb left right to forward or back without loading the pages again.
if you don't mind the cons, i strongly recommended you to try. personally I'm using outdated version of 7.8 instead of the current one at 10.xxx
donkohpwns
Keep brightness as low as possible? Around 30%?? I noticed quite significant difference in battery life by doing this.
scubyti
I switch on stamina mode and whitelist WhatsApp and Skype only. Disable all apps auto update or push notifications. Auto sync for Gmail only. Usually does the tricks.
jazzman80
i never need to tune up > 50% on my Z3 as the brightness is enough.
like when at home in the room, I set to 0.
if night time outside, probably 20% should suffice.
jazzman80
i haven't really test the battery entirely on stamina mode because I rely on 'smart data switch pro' app.
I also off my auto sync.
gapboy
1.use dark wallpaper
2.do not use touch wake up option > i read this somewhere in XDA
3.display brightness < 50% depends on individual comfort
4.no autosync, no adaptive brightness
5.do not use alot "widgets" it takes up battery too, i use only essential one and i need from the store i.e WIFI manager, Silent toggle and calendar.
rssd21
I think dark wallpaper only applies for OLED displays.
LCD displays consume the same amount of energy for any colours.
gapboy
Perhaps you are right but then good not to use high contrast / brightness pictures as a thumb of rule.
"The energy consumption of LCD only varies depending on the backlight setting. The lower the backlight, the lower the power consumption. A basic LED LCD with its backlight set low will draw less power than OLED."
http://www.cnet.com/news/led-lcd-vs-oled/
jazzman80
once the phone gets warm and you are not watching video nor playing games, the app you are using is processing power (a gap between CPU total and CPU foreground). just force stop the app, and restart again.
Elnin0
is it not good to drain/use batt till it left with 5%? Becoz I always do that. I usually don't charge my phone in office.
I thot it is good to drain batt till last drop, else got memory effect. :s22:
Btw, Using Z1 Compact.
rssd21
That method is only good for previous generations of battery that is nickel-based.
The current generation battery is lithium-based and do not have the memory effect.
This type of battery will lose its capacity at faster rate if left to drain to low levels frequently, say like 20% and below.
There is no way to stop the battery from losing its capacity once it is made.
Frequent charging of lithium battery does not harm it, and is recommended to keep within the medium to high levels of battery to slow down the deterioration of battery capacity.
