Saabo King
- Aug 6, 2010
Dear Saabo king,
Can you do a reset factory default?
Best regard,
JK
Noted. Will do that tonight.
Dear Saabo king,
Best regard,
JK
Any idea if Media Bridge mode is supported in 5300?
Yes, that I'm aware, cause AC5300 is working with AC87R as well.Yes I am using media bridge - AC5300 with AC88U as bridge![]()
After a few days, i realise the current firmware is not ready yet. I am getting slower internet speed compared to my old D-Link DIR-865L. There are just some unknown issue when internet stops loading. My AC devices are not using AC band (on Tri-Band smart connect). WTFast is not working anymore. I cant login to configure now. This is getting me irritated.
I meant between 2x AC5300 as Media Bridge.
What is the speed U get from the wired devices connected to the AC88U ?
I'm using AC3200 as router and AC68U as bridge. I'm getting 702Mbps (on AC68U WebUI) but getting 300+Mbps (upload and download) on speedtest.net
hard power off and power on can login?
Hi Folks
If anybody looking for RT-AC5300, please PM me.
Cheers
No matter how i set. it always stuck at 173.3mbps.
I already force the router to use AC band. it doesnt seems like it is connected to AC.
Adapter - Intel AC7260
Anyone knows where got stock for AC5300? Want to buy and try.
Thank you Asus@sg.Dear Seller4,
RT-AC5300 out of stock and you need to wait for next weekday.
Best regard,
JK
