Should I change router?
Gr3yham3
hi all, currently i am using singtel fibre plan with my own asus ac66u router.. the router is placed in the living room, which is located furthest from my master bedroom in my 4 room flat..
i could not get a wireless signal in my master bedroom at all, so i resorted to homeplugs to see if e situation could be helped. however, even with homeplugs of different brands, the wireless coverage is poor is there is often no data uplink with the homeplug and e router, which could be due to poor wiring
i am not sure of the current wireless technologies, so will buying a new, more powerful router, help in terms of the wireless coverage??
Bieffe
My setup is similar to urs. But I'm using a TP Link RT4300 N router. Mid way I installed a repeater. So my coverage improved. Homeplugs to me are not impressive. Their signal may drop significantly.
Finally I bought a $400 Asus AC3200. This w/o the repeater covered so much better.
But mine is TP Link to Asus. A $180 vs $400 product so may not be fair.
Gr3yham3
How much better? So last time with ur old router,no signal in e master bedrm also?then now with ac3200 got signal?
With my hse layout,there is like 3 walls between e router n e master bedrm
WWE_Fan
You can consider the WiFi Mesh, recently launched. $10/mth for dual pack, additional unit at $5/mth. I'm using it to pair with Archer C7 on Singtel Fibre 300Mbps. the coverage is much further and I'm getting better readings on Wifi.
Gr3yham3
whats wifi mesh?
Gr3yham3
hmm ok found it, buts its a monthly subscription... i understand that its good, but my hse is not that big.... i just want to know if investing in a more powerful router will allow me to access e wireless in my master bedroom.. dun need it to be too strong a signal.. even a "1 bar" signal to allow simple surfing n streaming of vids can liao
Bieffe
Before with just old router. My signal is max 2 bars and intermittent. With extender better 4bars but speed test is slow. 20 to 40 Mbps.
With new router speed is now 60 Mbps. So still worth to change router I feel.
I felt the diff.
Get a repeater.
Alvinalvintan
Do note that repeaters actually halves your bandwidth.
So a 1Gbps goes through a repeater could only yield 500Mbps after the repeat. Though your WiFi range do increase.
Bieffe
I know bandwidth will drop but not always half right? It depends on environment and distance from primary router. So moving router still best and cheapest.
Bieffe
Get a super long lan cable so u can shift ur router so some where in the middle of the house. Then test all ur speed. Speed and signal will improve 10 folds .
Gr3yham3
hmmm getting a super long lan cable will mean there will be an ugly cable going from e living rm to the study or kids bedroom.. my wife will sure disagree one haha... form over function for her
saw some posts about someone who upgraded from ac68u to ac88u, n in e end the signal coverage like weaker also.. sigh, i also dunno man. networking always gives me headache
Snowblind
I used to face that in my parent's place. Used a repeater since my room had a blind spot. But like some mentioned, if ur repeater receives 5mbps, u will get Ard 2-3mbps. This will let you surf net and maybe youtube.
Also, if the repeater is going to be in your room, that signal must be decent also. I had to put my repeater as close to the door as possible to get the signal.
Bieffe
yup CFO all like that. The long Lan cable is for u to test...so u know what the diff.
Therefore if want wife friendly. Repeater is the only way. Or access point? Is basically same thing. Or u pOwer plug a wifi to the center of the house?
hnzfaz
Changing the router might or might not improve coverage, no matter what the advertising claims. I used the aztech router provided by singnet for sometime, then lately changed to asus ac3200. I find that the improvement of coverage is minimal.
I'm using tp link's wireless extender, which helped a lot with speed and coverage. Check my post about this extender:
http://forums.hardwarezone.com.sg/i...ered-excellent-wireless-extender-5241226.html
Gr3yham3
Hmm so u changed a router,then added a wireless extender?
Is there a way for u to test e signal for a rm that is 2 walls apart from e extender?
Bieffe
Even with extender your speed is indeed very slow.
Bieffe
that's why I say get the long Lan cable to temporary shift the router for testing. The DL the wifi analyzer app for testing.
Bieffe
also hoe far is ur extender from ur primary router?
