Goodshot
- Sep 20, 2013
Wondering why WD allows HGST to pioneer and take credit for these cutting edge techs when they are their parent company...
WD is overrated , just like notua fan
I highly trust HGST aka Hitachi reliability in HDD storage.
If they launched 10TB HDD, they must be really proud of their track record and innovation in always breaking new grounds.
nvr own a HGST hdd before, guess i will get them to replace my Seagate 2TB x 4 in my nas.
any 4TB HGST to recommend for nas usage?
got 4k prawn liao?
I also want leh![]()
no 3d prawn no talk...![]()
Seagate?!
Better replace fast.
I own a almost 10 year old 250GB Hitachi HDD. Till now rock solid and no bad sectors at all. Using as spare HDD for my PC.![]()
Better not risk it. replace it before they fail.my those seagate are almost 4yr old, no issue yet, touch wood.
4 years is reaching its EOL.
When they fail, they will fail together without warning, especially if you bought them together as a batch.I running Raid 5. Still got some margin of error, unless 2 of the 4 fails together.
Anyway, I am planning to upgrade to bigger capacity. Will look at HGST.
Now 4TB very cheap. Less than 200.
They will all fail without warning, this being a Seagate. Also, rebuild times for even just 1TBx4 array in RAID 5 can be so startlingly long that another drive can fail before it's done rebuilding.I running Raid 5. Still got some margin of error, unless 2 of the 4 fails together.
which model do u recommend for 4TB hdd?
HGST of course. Toshiba also uses HGST tech so that's an alternative if you don't mind shorter warranty (1 year ... not exactly much unless you buy enterprise drives?)
Degraded array write speeds are awful
Never take your chances.
