The Samsung Galaxy Note 5 Thread
tkl23786
Actually i still feels that hover-over-the-screen is quite useful (for n3), can see time or missed call and sms without touching the phone
Sent from the dark side of the moon using GAGT
edited:
my 'Gesture wake up' is working now. must hv disabled something:o
Settings-Accessibility-DexterityInteraction-Gesture wake up
In the *#0*# test menu, there is no longer any 'Gesture Sensor'. Its there on both Note 3 & 4.
The gesture is still there, just that it is now not obvious and straightforward to enable. Just follow what @atcomm mentioned and you can enable it. I have checked and is still there.
:D
tkl23786
waterballoon
hey if the tip of my S Pen kena a bit of scratches is it possible to make noise to Samsung and get a replacement?
renfred89
Wah. If u were the one who caused the scratches, then it's extremely sordid to make noise.. if it comes scratched out of the box, then maybe still acceptable. But ultimately it depends on how convincing your story is.
But I doubt u can get it changed no matter what. :D
human_shieldz
gesture of goodwill being outrightly taken advantage of..
first world problem.
Let time a friend told me she know someone use mouse, every year before warranty expire, he will make sure something happen to the mouse then send in for exchange. People don't realize this will ultimately add to the cost of new products.
tkl23786
Are you referring to the "tip" which is used to write?
You can replace it using the replacement tips that came packaged in the box.
Kindly refer to "page 27" of the Note 5 manual
Note 5 manual
http://downloadcenter.samsung.com/content/UM/201508/20150821044210180/VZW_SM-N920V_Galaxy-Note5_EN_UM_LL_5.1_OGE_FINAL.pdf
If you are referring to the other end of the S pen, which is the clickable part of the S pen, then it may be tricky to convince Samsung to replace the S pen.
By the way, you can buy S pen separately.
Igene
Just gotten mine (not exactly mine; Number is mine). Paid 68 after traded in G2 ($150). This weekend CIS got $100 off and some phone model got another $50 off. So total got $150 off. Plus $150 trade in. Jin happy sia. :D
kweeli
White n silver...which one your prefer?
Gold I found too reflective, black not my preference... only left white n silver. No chance to see white demo unit yet.
hsComu
under the light, do you feel uncomfortable on the reflection from the front top n bottom of screen
if you use phone in 'landscape' mode there are a reflections from the 'home' button edges (at least in comparison to note 4)
jskywalker
My Transport Sg Apps not compatible
I just received my Note 5 2-days back.
Tried to load in the usual Apps, but can't load My Transport Sg Apps. :s22::s11::eek:
Keeps saying not compatible...
