i have the miles davis tribute in the office and using it now. tonight i will try it out on my other iems - triplefi 10/westone 4r.
everything seems normal - so far have not experience any interruptions.
I am using flac files copied from cds. I do not have any high resolution files. Not sure what is this wide/normal/narrow settings which you are referring to (can tell me more?). I charged the unit yesterday and just tried playing music this morning. still exploring.
Just bought the Onkyo dxp1. with gain set as normal, my volume is set to 105. can i know if this is normal? what are your usual volume level - anyone keen to share.
My Pioneer is at 130 ~140/160 , Normal.
anyone experienced the player randomly crashing on you for the Onkyo player ?
Nope so far. Typical android pop up error?
Driving which iem? Outdoor volume? Kind of high at normal gain.
My Onkyo on SE low gain with volume less than 100, driving universal hybrid iem. Not sure if there is power diff between Pioneer n Onkyo. Indoor use. For outdoor maybe up to 120 same settings
I just noticed that some chinese words cannot display on the Dxp1 itself but look ok on the xdap link. anyone has this issue?
In terms of sound quality, which dap is better? Onkyo DP-X1 or Pioneer XDP-100R?
Onkyo is superior if going balanced.
There's no difference between the two if going SE.
(Been posted on head-fi that Onkyo uses single dac & amp for SE, and the two players SE out measure exactly the same)
I have heard both on single ended and they sounded different. Pioneer is cleaner and more neutral, while Onkyo is more musical while retaining very good clarity level.
YMMV.
