Path of Exile thread, the revival
Vulpix
Moderator
Moderator
oh. that one was the 1 fusing one.
tmd.. i spent all my currencies to spam fusing, still no 6L.
awesome.
I told you before liao. Everyday do Vorici save up fusing to buy a white 6L. Usually I buy a 6L if cannot link anything.
TrueBeliever_jh
my ping to my host also quite bad:s13:
i jus emailed MR.. see what they say..
TrueBeliever_jh
same setting as mine. Bino + Consuming Dark
but i dun get how he does the 100% chaos conversion..
damn.. Infernal Mantle can do it.. i vendored liked 1 of them:s31:
Vulpix
Moderator
Moderator
Bladefall jin OP, I only got some crit node but it's already destroying everything. :s13:
blong
finally a thread on reddit talking about technical issues.
and not sure if lockstep still working for you guys. i got 16ms ping but the lag spikes jus makes the game unplayable especially when the game jus stuck there and try to catch up. (you see everything speeding up)
Actually it has been happening since 2.0. The spikes can be real bad sometimes at the Singapore server. So I just play at the Australia server which is surprisingly smooth but well, you know - desync and rubber banding.
TrueBeliever_jh
you mean predictive mode right?
i always get desync when cyclone. :s13:
