If u go for SLI + nvme, it would be 8/4/4? Ur 2nd gpu would be running in 4x which isnt good.
Another way is. Run nvme via sata. It is possible to do that.
the GPU uses PCIe lanes connected to the CPU, while the M.2 uses PCIe lanes connected to the chipset, mutually exclusive. If you want to connect a PCIe card on top of 2 NVIDIA GPU in SLI, you will need to connect the PCIe card to a PCIe slot is not hardwired to the CPU PCIe lanes. question is which slot on the Maximus VIII Extreme is which. my guess is the 6th slot (last) is connected to chipset PCIs lanes, hence ok to be used with a x4 card (I think the PCIe cards you are looking at are x4 in slot length) with 2 cards in SLI.
why would it be running at PCIe 2.0? the Z170 chipset PCIe lanes are 3.0.Wun that be running at pcie 2.0 x4 instead of the recommended pcie 3.0 x4?
It will be half the bandwidth. Its gonna be the same as sata based.
And all this while, pcie CPU is provided max 20 lanes. Chipset can go up to 36 iirc. But no matter what, you are still limited by CPU.
Its the same theory as a x99 with 5820k. You can have 40 lanes in total, but limited by CPU 5820k which is only 28 lanes.
Would it be accurate to say that I still can slot in a x4 NIC to a slot linked to chipset PCIe which would link to CPU via DMI?
If by doing do won't affect my SLI and M.2 that is great news indeed!
looked through the Maximus VIII Extreme manual in greater detail, it looks like the 6th PCIe slot shares bandwidth with Sata ports 5 and 6, and to enable x4 on this slot will disable the 2 Sata ports. the M.2 shares bandwidth with the U.2 port, so that shouldn't be compromised for you.
The last slot always share x4 with either the m.2 slot or 2 sata ports. If it takes 2 GPUs he is only left with x4. And usually for that he still can choose to put a m.2 and leave out the sfp+ card which needs another x4. Which in all he has not enough lanes to meet all criterias.
Not unless he swap the m.2 to a sata based, then yes he can accommodate all. But no one is in a right state of mind to put a nvme on sata based as it will only give him a total of 1/2 the speed advertised.
